Debug Communication channel
2005-05-19 by Sridhar gadda
I want to use Ulink for downloading frimware as well as the �vision(keil) debug serial window to diplay result. I can display the string but not hex values.
my code is
#include <LPC21xx.H>#include <DebugIO.H>#include <stdio.h>void init_serial(void){ PINSEL0 |= 0x00000005; U0LCR = 0x83; U0DLL = 16; /* 57600 Baud rate @ 15MHz VPB clock */ U0LCR = 0x03;}int putchar (int ch) /* write character to serail port */{ #ifdef DEBUG return (__dbg_putchar(ch)); #else if (ch == '\n') { while(!(U0LSR & 0x20)); U0THR = '\r'; } while (!(U0LSR & 0x20)); return (U0THR = ch); #endif}int getchar (void) /* Read character from serial port */{ #ifdef DEBUG return (__dbg_getkey()); #else while(!(U0LSR & 0x01)); return (U0RBR); #endif}void puthex (int hex){ if (hex > 9) putchar('A' + (hex-10)); else putchar('0' + hex);}void putstr (char *p){ while(*p) { putchar (*p++); }}int main (){ #ifndef DEBUG init_serial(); #endifputstr("\n");putstr("\n The value in hex is 0x");puthex((byte >> 4) & 0x0F); / byte = 8 bit char value */puthex (byte & 0x0F);}
I can see the result on Hyperterminal but on serial window of IDE. I see only my srting The Value in hex is 0x and not hex values which I want to display.
where am I doing wrong.
Please help me out.
regards,
Sridhar
Debug communication channel
#include "DebugIO.H"
#define DBG_PUTCHAR __asm { /* Macro: DBG_PUTCHAR */ \
__asm CMP R0,#0x0A /* Check 'ch' for LF */ \
__asm BNE wwait /* Branch if not LF */ \
__asm wwait0: MRC p14,0,R1,c0,c0 /* Read DCC Control */ \
__asm TST R1,#0x02 /* Check W bit */ \
__asm BNE wwait0 /* Branch if W = 1 */ \
__asm MOV R1,#0x0D /* Insert CR Code */ \
__asm MCR p14,0,R1,c1,c0 /* Write CR to DCC */ \
__asm wwait: MRC p14,0,R1,c0,c0 /* Read DCC Control */ \
__asm BNE wwait /* Branch if W = 1 */ \
__asm MCR p14,0,R0,c1,c0 /* Write 'ch' to DCC */ \
#define DBG_GETKEY __asm { /* Macro: DBG_GETKEY */ \
__asm rwait: MRC p14,0,R0,c0,c0 /* Read DCC Control */ \
__asm TST R0,#0x01 /* Check R bit */ \
__asm BEQ rwait /* Branch if R = 0 */ \
__asm MRC p14,0,R0,c1,c0 /* Read from DCC */ \
#define DBG_ISKEY __asm { /* Macro: DBG_ISKEY */ \
__asm AND R0,R0,#0x01 /* Mask R bit */ \
#define DBG_CR2LF __asm { /* Macro: DBG_CR2LF */ \
__asm CMP R0,#0x0D /* Check for CR */ \
__asm MOVEQ R0,#0x0A /* Replace CR with LF */ \
// Write Character to Debug Channel
int __dbg_putchar (int ch) __arm {
DBG_PUTCHAR
// Read Character with echo from Debug Channel
int __dbg_getchar (void) __arm {
DBG_GETKEY
DBG_CR2LF
DBG_PUTCHAR
// Read Character from Debug Channel
int __dbg_getkey (void) __arm {
DBG_GETKEY
// Check if Character is available
int __dgb_iskey (void) __arm {
DBG_ISKEY
thanks
sridhar
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
