Thanks again. I am clearing the STA flag (and I see that the SIC is
also cleared simultaneously). I also checked my PINSEL0 register
setting and it should be the same as the LPC2129 for selecting I2C
bus (pins 50 & 58 on the LPC2214). I'm starting to wonder if this
problem is a peculiarity to the LPC2214 (but I haven't seen anything
specifically to I2C in an Eryata (yet))...
--- In lpc2000@yahoogroups.com, Karsten Weiß <kweiss@i...> wrote:
> Okay. Low on both lines means, that the I2C bus is busy at the
moment,
> which is definitively correct, if you outputted a start condition.
After
> your start condition was outputted and the corresponding interrupt
> occured, you have to reset the STA flag by writing 0x20 to I2CONCLR
and
> then writing the slave addr to I2DAT. Now, reset the interrupt flag
(by
> writing 0x08 to I2CONCLR). This should work. I'm using this on an
> LPC2129, but without any interrupt service (just waiting for a
change in
> the I2STAT reg.).
> Regards,
> Karsten Weiß
> Remis Norvilis schrieb:
> > Thank you for your prompt response Karsten! Unfortunately, I
believe
> > that I'm setting the I2C clock rate appropriately (PCLK = 3.6864
MHz,
> > desired I2C clock rate = 97 KHz. Therefore, I've set I2SCLH and
> > I2SCLL each with a value of 19 (0x13). I believe this is correct
> > > Propably, you have not set the baudrate for the I2C module. This
> > can be
> > > done using the I2SCLL and I2SCLH registers.
> > > A possible initialization if the I2C module kis the following:
> > (F_VPB is
> > > the Peripheric bus clock speed in Hz and baudrate is also
measured
> > in Hz).
> > > void i2c_init( unsigned long baudrate )
> > > unsigned int divider = F_VPB / baudrate; // calculate the
> > clock
> > > divider
> > > // Initialize Pin Connect Block:
> > > PINSEL0 |= 0x50; // P0.2 and P0.3 as
I2C
> > > pins! (This has propably to be changed according to the pinning
of
> > your
> > > chip)
> > > // Initialize I2C:
> > > I2C_I2CONCLR = 0x6c; // clearing all
flags
> > > I2C_I2CONSET = I2C_FLAG_I2EN; // enabling I2C
> > > I2C_I2SCLL = divider / 2; // I2CSCLL + I2CSCLH
has
> > to
> > > be equal to that divider!
> > > I2C_I2SCLH = divider - I2C_I2SCLL;
> > > hoping this helps,
> > > Karsten Weiß
> > > > I'm having difficulty with getting the I2C to work (with the
> > LPC2214 as
> > > > the master). I can get as far a valid start condition (0x08)
and
> > > > generate an interrupt, but I can't get the clock line (SCL) to
> > > > oscillate. If I debug, it appears that both the clock (SCL)
and
> > the
> > > > data line (SDA) go low simultaneously after start flag is set
> > (STA in
> > > > the I2CONSET register).
> > > > After the interrupt is generated, I attempt to send an
address,
> > (by
> > > > setting the contents of the I2DAT to a valid PCF8574 slave
> > address 7-
> > > > bit value + a "0" for a "write" (ex. "0x40")). Both the SCL
and
> > SDA
> > > > lines appear to remain low until the start flag &/OR the
> > Interrupt flag
> > > > is cleared (by setting either the STAC &/OR the SIC bits in
> > > > I2CONCLR register). I've also tried to set the address value
in
> > the
> > > > I2DAT register after clearing the start &/OR interrupt flags
with
> > the
> > > > same result.
> > > > Note: I do have 10K ohm pull-up resistors (to 5v) on both the
SDA
> > and
> > > > SCL lines.
> > > > *Yahoo! Groups Links*
> > > > * To visit your group on the web, go to:
> > > > http://groups.yahoo.com/group/lpc2000/
> > > > * To unsubscribe from this group, send an email to:
> > > > lpc2000-unsubscribe@...m
> > > > <mailto:lpc2000-unsubscribe@yahoogroups.com?
> > subject=Unsubscribe>
> > > > * Your use of Yahoo! Groups is subject to the Yahoo!
Terms of
> > > > Service <http://docs.yahoo.com/info/terms/>.
subject=Unsubscribe>Show quoted textHide quoted text
> > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
