need i2c help please
2005-05-23 by b clapper
Hi Everyone, I'm having a problem with an i2c interface between LPC2138 and an image sensor. I'm using i2c to set parameters in the image sensor, like exposure, rgb gain, clocking etc. After capturing a frame, I'm trying to use i2c to get information back from the sensor about the relative brightness of the frame. I hope to use this to adjust my exposure setting. Anyway, I'm able to write the parameters to the image sensor without problems (I think) but I'm not having success reading. I know I can set some parameters correctly because I can change clocking, for example, and see it on the scope. Unfortunately, I can only read a few parameters before I start seeing unrecognizable settings. I hooked my board to the scope and trapped the waveforms on the SCL and SDA lines while reading and here's what I see. (By the way, I have a tektronix tds1002 - and I'm not sure if this is adequate to 'catch' everything I need). - successful start condition. - successful send of slave_address + R bit - ack by receiver (camera in this instance) Then, I see a blip on the sda line. It goes from low to high and then pulled low again before the next SCL peak. I *think* this is ok, but not sure. I think this is the LPC releasing SDA after his ack, and the camera taking control of it to start sending data. Anyway, next I see the data coming. 8 bits, 1 ack bit, then the blip. This might happen for another byte or two and then I see 8 data bits, and ack bit and then no 'blip'. At this point, the SDA line goes high and stays high - until the lpc acks eight high bits. All data from this point, of course, is 0xFF. It doesn't happen in the same place but it always happens. Sometimes I read 3-4 bytes, other times 1 or 2. I'm trying to read 20. It seems as if the camera has left the building and the LPC is talking to himself! The image sensor is still running (I can measure his pxlclock, vsync, hsync, etc). Anyway, I'm not sure if I've got a configuration problem or a timing problem or what. I've tried slowing down the i2c clock from 400khz to 100khz, I tried using different values for the duty cycles (SCLH/SCLL - not sure what that does if anything). I've made sure that I2CON_AA is set after each read to ensure I get an ack. I do that for all reads except the last one. Is it possible for the camera to see a stop condition and not the LPC? Anyway does anyone have any ideas of what I might look for or try? If not, do you know an i2c expert in Europe or the UK (the closer to Zurich Switzerland better for me)? Any pointers or consideration would be greatly appreciated. thanks, Bryan
