Robert Adsett wrote:
> At 11:37 AM 5/25/05 -0400, Brett Delmage wrote:
>>Now, can anyone tell me if there is clean, way to generate faster code than:
>>#define REG(addr) (*(volatile unsigned long *)(addr))
>>#define REG8(addr) (*(volatile char *)(addr))
>>in gcc? I don't like the multiple instruction to generate the address
>>each access, but maybe that is typical/not bad. I'm
>>relatively new to ARM and RISC.
> I haven't done a comparison of code generation but I use ld in combination
> with gcc for this.
> IE in the appropriate ld control file I have something like
> /* SYSTEM CONTROL BLOCK */
> /* MAM */
> PROVIDE( MAMCR = 0xE01FC000);
> PROVIDE( MAMTIM = 0xE01FC004);
> then in a header file
> /* MAM */
> extern unsigned char MAMCR;
> extern unsigned char MAMTIM;
> You can see this in the newlib-lpc source.
Incidentally Robert, I had to add a couple of volatiles to the
newlib-lpc lpx2XXX.h file in my case where you'd left them out (but most
registers had them). Probably for a case you weren't expecting, but I
was re-programming PINSEL registers before sleeping.
Gcc had done a trick of moving the updates around since not specified
volatile and of course it had weird (and non-obvious) results. Only
found the problem eventually by looking at the assembly code.
May be worth having a thought experiment on any other non-volatile
registers specified.
Bruce
/\\\/\\\/\\\ / / Bruce Paterson
/ \\\ \\\ \\\ / / Senior Design Engineer
/ /\\\/\\\/\\\/ / 8 Anzed Court, Mulgrave, Vic, 3170
/ / \\\ \\\ \\\ / PO Box 4112, Mulgrave, Vic, 3170, Australia
/ / \\\/\\\ \\\/ Ph: +61 3 8561 4232 Fax: +61 3 9560 9055
Tele-IP Ltd. Email: bruce@... Icq: #32015991
WWW: http://www.tele-ip.com VK3TJN
