Lpc2000
Free LPC2xxx bootloader update tool
2005-05-26 by tildesign2
The earlier LPC2xxx ARM processors require a bootloader update in
order to protect the code from being read through ISP.
We created a free update tool that is suited to reprogram any number
of LPC2xxx microprocessors quickly and fool proof. The update tool
provided by Philips works just fine, but only for engineers and the
update job is quite tedious.
Our LPC2xxx updater has a command line interface, so it can be
integrated in a production tester as well.
For more information and downloads, check
http://www.tildesign.nl/LPC2000_update_utility-20107101Q2Y
RE: [lpc2000] Free LPC2xxx bootloader update tool
2005-05-26 by Matthew Kavalauskas
This seems pretty similar to LPC21ISP
(http://guest.engelschall.com/~martin/lpc21xx/isp/).
How stable is this new utility?  I am currently calling LPC21ISP from
Eclispe, and I occasionally get the blue screen of death when using it.
Matt
From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf
Of tildesign2
Sent: Thursday, May 26, 2005 8:02 AM
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Free LPC2xxx bootloader update tool
Yahoo! Groups Links
*	To visit your group on the web, go to:
	http://groups.yahoo.com/group/lpc2000/
*	To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
*	Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
2005-05-26 by Robert Adsett
Interesting, I'm currently making some changes to it, including some error
checking, so I'd be interested if you could provide any information.  I
will be feeding the changes back to Martin but they have to settle down a
bit first.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
Re: Free LPC2xxx bootloader update tool
Hi Matt,
we bought about 320 LPC2114's as soon as they were available. These
needed updating. During this process everything went just fine. No
crashes at all.
I'd say, just try it for yourself, it's free.
Tjark
--- In lpc2000@yahoogroups.com, "Matthew Kavalauskas"
from
using it.
> Thanks,
> Matt
Behalf
> Of tildesign2
number
After some digging, it turns out that it is not the LPC21ISP that is
causing the blue screen.  Rather I have traced it down to a corrupt
USB-to-serial driver.
Sorry for crying wolf.
Matt
Of Robert Adsett
Sent: Thursday, May 26, 2005 11:34 AM
Subject: RE: [lpc2000] Free LPC2xxx bootloader update tool
error
a
bit first.
Robert
be
a
Yahoo! Groups Links
2005-06-28 by tildesign2
We did some more tweaking to make some improvements. The newest
release [V1.0r2] of our free bootloader update tool is now available
from http://www.tildesign.nl/LPC2000_update_utility-20107101Q2Y
Tjark
Re: [lpc2000] Re: Free LPC2xxx bootloader update tool
2005-08-26 by Jim Parziale
How do you get this utility to work? All I get is an error:
"The application failed to initialize properly (0xc0000022). Click OK to
terminate the application."
Is there some trick to get it to work?
> Tjark
Jim Parziale
Email: nuncio.bitis@...
Malden, MA
2005-09-08 by tildesign2
Hi Jim,
Can you please send an email to lpc@... so we can
communicate with you directly.
We really want to solve this problem and help you out.
best regards,
Tjark
--- In lpc2000@yahoogroups.com, Jim Parziale <nuncio.bitis@g...>
OK to
available
> > Tjark
> > Yahoo! Groups Links
> Jim Parziale
> Email: nuncio.bitis@g...
> Malden, MA
2005-09-09 by Jim Parziale
Hello -
Just this past weekend I tried using an older version of the bootloader
utility and that seems to be working fine. In fact, it merely informed me I
already have the latest bootloader code on my LPC-P2106...
Thanks!
Jim Parziale
On 9/8/05, tildesign2 <lpc@...> wrote:
>  Hi Jim,
> best regards,
> Tjark
> OK to
> available
> > > Tjark
> > > Yahoo! Groups Links
> > Jim Parziale
> > Malden, MA
> YAHOO! GROUPS LINKS
>    - Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000>"
>    on the web.
>     - To unsubscribe from this group, send an email to:
>    lpc2000-unsubscribe@yahoogroups.com<lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     - Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>    Service <http://docs.yahoo.com/info/terms/>.
Jim Parziale
Malden, MA
