Lpc2000
IRQ LPC2194
IRQ LPC2194
2005-06-02 by Steffen Rose
I'm "playing" with interrupts.
Now I have this situation:
Within the VIC some Interrupts are enabled and set.
The ARM7 Core is in Usermode, the I Flag is 0.
Now I miss my Interrupt generation.
What could be wrong?
Before this situation, for example I clear the Interrupts on the
VIC with
    /* disable all Interrupts on the VIC unit */
    LPC21_VIC_INT_ENCLR = 0xFFFFFFFFul;
    /* reset current interrupt Flags */
    LPC21_VIC_SOFTINT_CLR = 0xFFFFFFFFul;
Later I generate a SWI. Within the Software Interrupt function I
call this function:
void fl_destroyAppl(void) __arm
    /* disable IRQ, FIRQ (Mode_SVC|I_Bit|F_Bit) */
    __asm {
		MSR CPSR_c, #0xD3 	/* (Mode_SVC|I_Bit|F_Bit) */
                LDR     R0, =0xE01FC040 /* MEMMAP */
                MOV     R1, #1 	/* User Flash Mode */
                STR     R1, [R0]
    ((void(*)(void))0)();
On address 0 the program restarts and the startup initializes and
enables the interrupts. But now the Interrupt engine is wrong.
Do you have a better command to reset the CPU? I want also reset
the internal resources. But I didn't find a Software Reset.
Thank you.
Steffen Rose
Re: [lpc2000] IRQ LPC2194
2005-06-02 by Jim Parziale
Have you tried using the Watchdog Timer to reset?
On other projects I've noticed that just jumping to address 0 can leave
the processor in a strange state (it's not really resetting the
processor), and subsequent interrupts were ignored until we hit the reset
button.  If you have a Watchdog Timer, that may work better to reset the
processor state.  Just set the timeout value to something small, but long
enough to execute the next few instructions (so you can clean up stuff and
enter an infinite loop)
Jim
--- Steffen Rose <ro@...> wrote:
> Hi,
> VIC with
> call this function:
>     __asm {
>                 STR     R1, [R0]
> Thank you.
> Steffen Rose
Jim Parziale
Email: nuncio_bitis@...
Malden, MA
Discover Yahoo!
Find restaurants, movies, travel and more fun for the weekend. Check it out!
http://discover.yahoo.com/weekend.html
2005-06-03 by Steffen Rose
Hi Jim,
Thank you for this hint. Now it works.
But, what can I do, if the Watchdog is configured to generate
IRQ's? Can I change it to Reset-Generation?
Steffen Rose
2005-06-03 by Jim Parziale
Hmmm... where the WDT is and to what signal it's attached in the processor
could be hardware dependent.  If the watchdog isn't attached to the
processor reset, I don't know what then.  Is there another way you could
reset the processor from software?  I've never seen a watchdog timeout
*not* reset the processor.
> Hi Jim,
> Steffen Rose
Jim Parziale
Malden, MA
Discover Yahoo!
> the processor could be hardware dependent.  If the watchdog
> isn't attached to the processor reset, I don't know what then.
>  Is there another way you could reset the processor from
> software?  I've never seen a watchdog timeout *not* reset the
> processor.
On the Philips ARM it is possible to configure for Reset or for
IRQ generation by software.
> > generate IRQ's? Can I change it to Reset-Generation?
I don't find information, which parts of the watchdog are
protected after it is enabled.
Steffen Rose
Just for the purpose of resetting, couldn't you configure the WDT for
reset?  Then in your startup code you must already set it for IRQ.  That
wuold definitely work out well for you.
Jim Parziale
Malden, MA
Do You Yahoo!?
http://mail.yahoo.com
