Lpc2000
memory writing
memory writing
2005-06-06 by gfaurie1
Hello,
On a Philips LPC2294, when i reset, the internal bootloader write
FFFFFFFFh at adress 40000128h.
During a debug session with Keil environment, when i press "reset
button"(which is a micro reset), and i watch memory at adress
40000128h, memory at this location is changed to FFFFFFFFh.
I just press "reset" and i don't press "go".
I have no code in flash.
I tried to find information in database of this group but
unsuccessfully.
Let me know if someone has the same problem.
Thanks
Re: [lpc2000] memory writing
2005-06-06 by Steffen Rose
> write FFFFFFFFh at adress 40000128h.
> "reset button"(which is a micro reset), and i watch memory at
> adress 40000128h, memory at this location is changed to
> FFFFFFFFh.
Could it be, that the ISP Command handler changed it?
The Documentation write, that the ISP use the memory location
0x40000120-0x400001FF.
Note, that the ISP runs a little bit code before you stop within
your reset vector, especially if you don't have code in flash.
Steffen Rose
Re: memory writing
2005-06-07 by gfaurie1
Thanks for your answer i think that you agree !
--- In lpc2000@yahoogroups.com, Steffen Rose <ro@p...> wrote:
> Hi,
> > FFFFFFFFh.
> Steffen Rose
