Lpc2000
LPC2138 supply current in power down (attn please Phillips Apps)
2005-06-07 by Owen Mooney
Previous posts on this site by Robert (Philips Apps) indicated a power
down current for the LPC2138 of about
50 uA in addtion to a RTC current of 20 uA.
The data sheet "LPC2131_32_34_36_38_2.pdf"  revison 20050516 indicates
60 uA Typ, 500uA max at 85degrees
I would really like to know how to achieve this because the best I have
achieved is 700 uA. This is with just a micro + Xtals + caps + a
RS232 converter circuit measured at 1 uA
I have based my design decision about this consumption - If it can't be
achieved I need to find another micro, buy tools and re-layout!!!!!.
I am not the only person to find this. Correspondence with another group
member below.
Any information would be most welcome
Owen Mooney
Correspondence:
Hi "relentless_6995"
I am mailing you because you put a post on the LPC2000 group
I am trying to put a LPC2138 into power down mode, but I am getting 700
micramps
consumption. I've done the obvious things:  put unused ports as outputs
to prevent parasitics
checked the uart circuit (less that 1 uA) the only other things on the
board are the 2 xtals and their caps!
What power consumption did you get? and any hints?
Thanks
Owen Mooney
Owen,
Well that's curious - cause I also was able to only get down to 700uA as
well. I stopped at that point cause that will probably be okay for this app
but that is a lot higher than I expected. I do not have the RTC powered as
you might (you mentioned 2 xtals). I also hunted for floating inputs.
Powered down all the peripherals (though that seemed to make no difference).
Not sure what to try next.
I really would like to know what it "should be".
Can you copy our text so far to the group? Perhaps we could get further
along.
Bob Destremps
Re: LPC2138 supply current in power down (attn please Phillips Apps)
2005-06-08 by Richard
I am impressed that you can drive RS-232 at ONE uA.
Richard
group
> member below.
> Owen Mooney
> Correspondence:
> micramps
> Thanks
> Owen Mooney
> Owen,
this app
powered as
difference).
> along.
> Bob Destremps
2005-06-08 by valdef78
> Richard
that's what is on Maxim datasheets for several of their RS232
converter in AutoShutdown mode.. probably something like that here..?
2005-06-08 by lp2000c
The copy of Data Sheet "LPC2131_32_34_36_38_2.pdf" which I see on the
Philips site is dated 15 April 2005.  Where did you find revison
20050516?
indicates
