Lpc2000
LPC2131 ADC Input Impedance
2005-06-06 by drb5599
Sorry if this is an obvious question.  But, I have looked at the User
Manual, and all other documentation I have and can not find a
specification for input impedance on the ADC input pins????
Does anybody know what this impedance is??
I am going to be feeding a signal with a 200k impedance to one of the
ADC inputs and am trying to figure out if I need a buffer or not.
Dave Butler
Re: [lpc2000] LPC2131 ADC Input Impedance
2005-06-07 by Robert Adsett
Unfortunately I don't belive that's documented anywhere.
Well, something.  An op-amp if that's the kind of buffer you are thinking
of may not be needed.  Depending on your scan rate a capacitor or better, a
small rc filter may be sufficient.  If you are only converting on this
channel at 100 Hz or so a 1k /.01uF cap will provide some noise and Nyquist
filtering and give you enough charge storage that you won't need the
buffer.  You would need the filter anyway so....
It's likely that you will want the charge storage anyway so that you don't
need an unreasonably fast op-amp.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2005-06-08 by rseku
I'm not sure, that You know if high source impedance will increase
sample collection time.
> Thanks,
> Dave Butler
Re: LPC2131 ADC Input Impedance
2005-06-08 by drb5599
Yes, Good point.  I will not be sampling this pin very fast at all,
so speed is not really the issue in this particular application.  I
am really more concerned with making sure the impedances are not
completely out of range.  I would like to assume it is in the 10k
range????
I think I am going to use a buffer to start out with, I would really
like this proto to work.
Thanks for the input.
-Dave
User
of the
> > Thanks,
> > Dave Butler
> > Yahoo! Groups Links
