Lpc2000
Reading the frequency
2005-06-08 by soren_t_hansen
Hi Group
Is it possible to read a register or read a pin to see what frequency
the processor is running at? I would like to make sure, that my
LPC2132 is running at the maximum 60 Mhz.
I have a Xtal of 12 Mhz and have set the PPL to 5, thus giving 60 Mhz,
but how can I make sure ....?
Best Regards
Søren
Re: [lpc2000] Reading the frequency
2005-06-08 by Robert Adsett
Without an independent clock source it would be impossible to tell how fast
the processor is running.
Check your baud rate if using a UART.  Program a timer or PWM to produce a
specific pulse width.
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
Re: Reading the frequency
2005-06-08 by dukearmlover
--- In lpc2000@yahoogroups.com, "soren_t_hansen" <
soren_t_hansen@y...>
wrote:
> Hi Group
frequency
Mhz,
> Best Regards
> Søren
Hello,
I had exactly the same problem. Running my very first program on a
LPC2129 - Olimex LPC-P2129 (using GCC4.0.0) gave me exactly the same
impression. I was not sure the PLL settings were correct because
the 'blinking led' was blinking slower than expected.
On some LPC2000 derivatives (e.g. the LPC2214 in 144-pin package),
you
have the possibiliy to configure one special XCLK pin to generate an
image of the internal clock.
On the LPC2132, and also on my LPC2129, this pin is not implemented.
But there is a workaround (what I did). You can e.g. configure the
PWM
unit to generate a square wave that is proportional to the clock. If
you set the VPBDIV factor to 1, the PWM prescaler to 0, and use a PWM
cycle (register PWMMR0) of 1000, with channel 1 at 50% duty cycle
(PWMMR1 = 500), you will get a square wave at exactly 60 kHz for
60MHz
clock frequency. This is a way to implement a frequency division by a
factor 1000.
When I checked the waveform on the pin with an oscilloscope, I
noticed
the frequency was 14.7 kHz instead, denoting a wrong PLL factor in my
case. After code inspection, I found a mistake in the macros I used
to
program the PLL (missing left shift by 5 bits to align correctly a
bitfield). Correcting the macro gave the correct result.
So the method works !
Regards.
"Duke"
