Setting up LPC2132 ADC in Hardware mode
2005-06-08 by soren_t_hansen
I followed the example from the Insiders guide from Hitex, but it
seems if it is designed only for the Keil ARM compiler. Also I suspect
it to have an error where ADCR should be ADDR.
Anyway the interrupt function doesn't get called, and I have no clue
why not. In the Keil example they make a change in the startup.s, but
doing that didn't solve the problem.
How do I set up the ADC to hardware mode, using the GNU ARM toolchain?
My program looks like this:
void AD_ISR (void)
unsigned val, chan;
static unsigned result[4];
val = AD0DR;
val = ((val >> 6) & 0x03FF);
chan = ((AD0CR >> 0x18) & 0x07);
result[chan] = val;
int main (void) {
//The ADC setup
VPBDIV = 0x00000002;
AD0CR = 0x00270607;
VICVectCntl0 = 0x00000032;
VICVectAddr0 = (unsigned)AD_ISR;
VICIntEnable = 0x00040000;
IODIR1 = 0x00FF0000; /* P1.16..23 defined as Outputs */
while(1)
The vector table in the startup.s look like this:
Vectors: LDR PC, Reset_Addr
LDR PC, Undef_Addr
LDR PC, SWI_Addr
LDR PC, PAbt_Addr
LDR PC, DAbt_Addr
NOP /* Reserved Vector */
LDR PC, IRQ_Addr
LDR PC, FIQ_Addr
Reset_Addr: .word Reset_Handler
Undef_Addr: .word Undef_Handler
SWI_Addr: .word SWI_Handler
PAbt_Addr: .word PAbt_Handler
DAbt_Addr: .word DAbt_Handler
.word 0 /* Reserved Address */
IRQ_Addr: .word IRQ_Handler
FIQ_Addr: .word FIQ_Handler
Undef_Handler: B Undef_Handler
SWI_Handler: B SWI_Handler
PAbt_Handler: B PAbt_Handler
DAbt_Handler: B DAbt_Handler
IRQ_Handler: B IRQ_Handler
FIQ_Handler: B FIQ_Handler
Best Regards
Søren
