Lpc2000
How fast can it go?
How fast can it go?
2005-06-28 by markevans_1
Hi guys,
I am finding it a little tricky to calculate how fast this chip can
actually go for my app. (Instruction cycles and MAM)
I was wondering if anyone can tell me how fast it would execute this
code at 60MHz:
Read in 16 bits from port1
store in RAM
increment pointer
loop for N times
I basically want to buffer data as fast as possible in bursts. Ideally
at 20MHz.
How much faster would it execute in RAM.
Could I make it faster by using an infinite loop and using a timer to
'break out' of the loop.
Mark.
Re: [lpc2000] How fast can it go?
2005-06-28 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Tuesday, June 28, 2005 2:01 AM
Subject: [lpc2000] How fast can it go?
> Hi guys,
> code at 60MHz:
> store in RAM
> increment pointer
> loop for N times
> at 20MHz.
The limiting factor is reading in the data from the port, it's very slow.
You won't get anything like 20 MHz, 3 MHz max. at a guess.
Leon
Checked by AVG Anti-Virus.
Version: 7.0.323 / Virus Database: 267.8.2/29 - Release Date: 27/06/2005
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
2005-06-28 by Robert Adsett
At 01:01 AM 6/28/05 +0000, markevans_1 wrote:
>Hi guys,
>code at 60MHz:
That's the slow part.  Pin toggle rate is about 3.8MHz.  Narrowest part of
that has a time of 118nS.  If you need to run any sort of handshaking slow
that down by at least 2to 3x.
See a very early thread in this forum titled "Simple test program - is now
instruction pipeline/VPB question" about Nov/Dec 2003.
>store in RAM
>increment pointer
>loop for N times
>at 20MHz.
Not going to happen without external support.
Probably not enough faster to notice. The port access time is going to be
noticeable,
>Mark.
>Yahoo! Groups Links
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
Re: How fast can it go? The LPC2148 much faster :-)
2005-06-28 by philips_apps
Hi all,
today the LPC2148 was announced to the press. The preliminary DS has
been posted on this group by our marketing recently. One very
important improvement is the port access time. This is the first
device that has the ports mapped to the local bus. This enables 4
times faster toggle times. The max is now Processor clock divided by
4. This will not get you to 20 Mhz but 15 is as close at it will ever
get (without increasing the max. clock rate).
May be 15 MHz is fast enough ?
We plan to have evaluation boards through IAR and Keil available
second half of July.
Hope this helps, Robert
--- In lpc2000@yahoogroups.com, Robert Adsett <subscriptions@a...>
> >Hi guys,
this
> >code at 60MHz:
part of
handshaking slow
is now
> >store in RAM
> >increment pointer
> >loop for N times
Ideally
> >at 20MHz.
to be
> noticeable,
to
> >Mark.
> >Yahoo! Groups Links
restrictions,   be
chew a
2005-06-28 by Karl Olsen
> code at 60MHz:
> store in RAM
> increment pointer
> loop for N times
I'd guess around 13/15 clocks (4.6 MHz / 4.0 MHz) when executing out
of RAM/flash.
Generally for LPC2000 chips, MAM enabled, MAMTIM=3:
Simple ALU instruction: 1 clock
Load from RAM: 3 clocks
Store to RAM: 2 clocks
Load constant from flash: 3 or 5 clocks, depending on MAM hit/miss
Load from VPB peripheral (GPIO, timer etc.): 8 clocks
Store to VPB peripheral: 7 clocks
Jump (executing from RAM): 3 clocks
Jump (executing from flash): Normally 5 clocks, sometimes 3 clocks
with short backward jumps
Skipped conditional instruction: 1 clock
The speed of loads/stores to the VIC is somewhere between RAM and VPB
timings, I don't remember my exact measurements.
> Ideally at 20MHz.
I don't think this is possible, even with the coming LPC214x.  If a
GPIO load takes 3 clocks in the new chips (philips_apps: do they?)
and a RAM store takes 2, you will end up with at least 5 clocks, or
12 MHz.  This is when you completely unroll your loop so there is no
loop overhead.
For very short bursts, you can:
  ; r0 = IOPIN0
  ldr r1, [r0]
  ldr r2, [r0]
  ldr r3, [r0]
  ldr r14, [r0]
and then store the registers afterwards.
> to 'break out' of the loop.
Not much, you could save one clock for decrementing the loop
counter.  You will gain more by unrolling the loop.  If you require
completely uniform sampling times, you have to unroll the loop
completely:
  ; r0 = IOPIN0
  ; r1 = RAM pointer
  ldr r2, [r0]
  strh r2, [r1, #0]
  ldr r2, [r0]
  strh r2, [r1, #2]
  ldr r2, [r0]
  strh r2, [r1, #4]
  ldr r2, [r0]
  strh r2, [r1, #6]
  ; etc etc
Karl Olsen
--- In lpc2000@yahoogroups.com, "philips_apps" <philips_apps@y...>
> has been posted on this group by our marketing recently. One very
> by 4. This will not get you to 20 Mhz but 15 is as close at it will
> ever get (without increasing the max. clock rate).
Can you do ISP through the USB device port, or do you still need a
serial port for that?
Karl Olsen
2005-06-28 by dave_baker_100
Excellent! A semiconductor manufacturer listening to the users and
then responding in a relatively quick time (taking into account tape
out times & validation). This will help Philips to stay ahead of the
competition. The only other thing I'd add is that the datasheet people
should also listen to the users in this group or even look at other
manufacturers datasheets to see how its done ! (checkout Silicon Labs
as an example of excellent, albeit non-ARM, datasheets)
Dave
wrote:
> Hi all,
ever
> > >Hi guys,
can
> this
> > >code at 60MHz:
> part of
> handshaking slow
> is now
> > >store in RAM
> > >increment pointer
> > >loop for N times
> Ideally
> > >at 20MHz.
going
> to be
> > noticeable,
timer
> to
> > >Mark.
> > >Yahoo! Groups Links
> restrictions,   be
> chew a
Dave,
same people listening to all of you here, replying to the forum,
specifying new features, writing documentation....
Will do our best to catch up and improve documentation!
Robert
--- In lpc2000@yahoogroups.com, "dave_baker_100"
tape
people
Labs
> Dave
> wrote:
> > Hi all,
has
by
> ever
> > > >Hi guys,
chip
> can
execute
> > this
> > > >code at 60MHz:
Narrowest
> > part of
> > handshaking slow
program
> > is now
> > > >store in RAM
> > > >increment pointer
> > > >loop for N times
> > Ideally
> > > >at 20MHz.
> going
> > to be
> > > noticeable,
> timer
> > to
> > > >Mark.
> > > >Yahoo! Groups Links
> > restrictions,   be
to
> > chew a
Re: How fast can it go? The LPC2148 much faster :-) // No ISP through USB yet
Karl,
we did not plan to offer ISP through USB because it would
significantly increase the code size for ISP on the chip. However,
you are at least the second person interested in this feature within
one weeks time. Based on the overall feedback we will get, it is an
option for future implementations but very difficult to get the ISP
through USB into the existing device, the memory holding the ISP code
would not be sufficient.
Robert
will
> Karl Olsen
Re: [lpc2000] Re: How fast can it go? The LPC2148 much faster :-)
2005-06-29 by Robert Adsett
>Robert
Sounds good Robert, just please don't combine the data sheet and user
manual into a single document.  That would be a giant step backwards.
Robert
