Lpc2000
[gcc] linker script for data in eeprom/fram spi
2005-07-05 by Jaromir
Hello All,
I try used linker for automatic assigment adresses for data stored in fram (spi or i2c).
Its possible ?
I saw in WinAVR, that I can use macro like this:
    #define EEPROM__attribute__ ((section(".eeprom")))
next I can define variable:
    int number EEPROM;
and  "&number" return valid addres in eeprom.
My linker scipt is something like this:
MEMORY
flash : ORIGIN = 0, LENGTH = 512K
ram : ORIGIN = 0x40000000, LENGTH = 32K
fram_spi : ORIGIN = 0x10000000, LENGTH = 8K
__stack_end__ = 0x40000000 + 32K - 4;
SECTIONS
FRAM_SPI :
*(.fram)
} >fram_spi
. = 0;
startup :
*(.startup)
} >flash
But lpc21isp and philips isp  throw some errors:
lpc21isp(v1.27) : Record Type 04 not yet implemented - ignore?
philips flash utility:
"Code in Hex file exceeds Flash Limitations"
List sprawdzony skanerem poczty mks_vir ( http://www.mks.com.pl )
Re: [lpc2000] [gcc] linker script for data in eeprom/fram spi
2005-07-05 by 42Bastian Schick
Jaromir
Maybe try NOLOAD
> FRAM_SPI :
> *(.fram)
> } >fram_spi
FRAM_SPI NOLOAD:
*(.fram)
  } >fram_spi
If NOLOAD does not work use objcopy to remove the FRAM_SPI section from
the ELF
before downloading.
42Bastian Schick
2005-07-06 by Jaromir
Thanks Bastian !
This works!
FRAM_SPI  (NOLOAD):
 *(.fram)
} >fram_spi
Jaromir
