Lpc2000
Olimex lpc e2294 board interrupt help - GNU C
2005-07-28 by boje_d
Hi im trying to make the interrupt work om a lpc2294. I am using
timer 0 and see the interrupt being enabled (test routine on display)
but the interrupt does NOT activate the interrupt routine. Ill put in
some code so maybe someone can see my error??? And give a little
help ??
than you (i hope)
Best regards
Boje Demant
interrupt routine
static void Timer0Interrupt(void) __attribute__ ((interrupt ("IRQ")));
static void Timer0Interrupt(void){
//  (*timer_function)(); // Call timer callback function.
//   T0_TCR=0; //stop timer
//   T0_TCR=2; //Reset timer
//   T0_TCR=1; //start timer
   LIGHT_LCD_ON;
   T0_IR = 0xff; // Clear timer 0 interrupt line.
   VICVectAddr=0xff;
in main:
T0_PR=58982;  //setup prescaler = 1msek
T0_TCR=0x00000002; //Reset timer
T0_MR0= 1500; //2 (2 sek for  interrupt;
T0_MCR=0x00000003; //generate interrupt on match
VICProtection=0;  //
VICIntEnClear=0xffffffff; //disable all interrupts
VICSoftIntClear=0xffffffff;
VICDefVectAddr=(unsigned long)&DefInterrupt;
VICIntSelect=0x00000000;      //assigne interrupt timer 0 til type IRQ
VICVectAddr0= (unsigned long)&Timer0Interrupt;   //opsæt vector
VICVectCntl0= 0x00000024;                 //enable vector iterrupt
Re: [lpc2000] Olimex lpc e2294 board interrupt help - GNU C
2005-07-28 by DECwiz (Fred van Kempen)
In the ISR, you need to reset the VIC using 0x00, not ff:
VICVectAddr = 0;
will work.
Also, in main:
will not work.. you need to SET the bit for the specific VIC channel, such as:
VICIntSelect |= (1 << VIC_TIMER0);
or alike.
--fred
help ??
than you (i hope)
Best regards
Boje Demant
interrupt routine
   LIGHT_LCD_ON;
   VICVectAddr=0xff;
in main:
VICProtection=0;  //
SPONSORED LINKS
Microcontrollers Microprocessor Intel microprocessors Pic microcontrollers 8085 microprocessor
YAHOO! GROUPS LINKS
 Start your day with Yahoo! - make it your home page
Re: Olimex lpc e2294 board interrupt help - GNU C
2005-07-28 by Angel Sanchez
You have a couple of faults:
In Interruption: VicVectAddr = 0; (Not 0xff)
In main, include:
  VicIntEnable = 0x10;                    // Enable timer 0 interrupt
--- In lpc2000@yahoogroups.com, "DECwiz \(Fred van Kempen\)"
> VICVectAddr = 0;
> will work.
> Also, in main:
IRQ
channel, such as:
> or alike.
> --fred
display)
in
> help ??
> than you (i hope)
> Best regards
> Boje Demant
> interrupt routine
("IRQ")));
>    LIGHT_LCD_ON;
>    VICVectAddr=0xff;
> in main:
> VICProtection=0;  //
IRQ
> SPONSORED LINKS
> YAHOO! GROUPS LINKS
Service.
