Lpc2000
PINSEL2 crashes everything
2005-08-01 by soren_t_hansen
I'm trying to write to the PINSEL2 register, to ensure that it has 0's
at bit 2 and 3, but if I try to write to the register, the JTAG
connection drops, and it seems as if the MCU enter some other mode,
since I can't restore the connection whitout having to do a power cycle.
Has anyone experienced this?
And how can I write to the PINSEL2 register, whitout having this problem?
/Søren
Re: [lpc2000] PINSEL2 crashes everything
2005-08-01 by 42Bastian Schick
soren_t_hansen <soren_t_hansen@...> schrieb am Mon, 01 Aug 2005
14:04:44 -0000:
Some bits disable JTAG, be sure to set these to the correctly.
42Bastian Schick
2005-08-02 by Aalt Lokhorst
Hello Søren,
Not sure what processor you are using but I think you are diabling the JTAG by changing a JTAG line into a GPIO line.
I am using the LC2129 and the usermanual of this processor shows the following:
Table 63: Pin Function Select Register 2 for LPC2119/2129/2194
(PINSEL2 - 0xE002C014)
1:0 Reserved.
2 When 0, pins P1.36:26 are used as GPIO pins.
   When 1, P1.31:26 are used as a Debug port. (RTCK)
3 When 0, pins P1.25:16 are used as GPIO pins.
   When 1, P1.25:16 are used as a Trace port.  (TRACESYNC)
4:5 Reserved.  Note: These bits must not be altered at any time.
     Changing them may result in an incorrect code execution.
6:31 Reserved.
According to this info you are disabling the JTAG RTCK line.
Hope this helps,
Aalt
Aalt Lokhorst
Schut Geometrische Meettechniek bv
Duinkerkenstraat 21
9723 BN Groningen
P.O. Box 5225
9700 GE Groningen
The Netherlands
Tel: +31-50-5877877
Fax: +31-50-5877899
E-mail: Lokhorst@...m
> > /Søren
> YAHOO! GROUPS LINKS
> >     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>        >     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>        >     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Re: PINSEL2 crashes everything
2005-08-02 by soren_t_hansen
--- In lpc2000@yahoogroups.com, "Aalt Lokhorst" <lokhorst@s...> wrote:
> Hello Søren,
following:
> 1:0 Reserved.
> 6:31 Reserved.
> Hope this helps,
> Aalt
Ups forgot to tell - it's a lpc2132 :o)
I use the following line and it still crashes:
PINSEL2 = (PINSEL2 & (0 << 2) & (0 << 3));
At the moment it isn't that big a deal, since the PINSEL2 bit 2 and 3
are 0 at reset, and that's what I want them to be. It just pusled me
that I couldn't write to those two bits whithout the MCU crashing.
/Søren
Re: [lpc2000] Re: PINSEL2 crashes everything
Hello Soren,
I think your hardware is running fine, probably the behaviour is not what your expecting but that is not caused by a hardware failure.
Look in the User Manual of the LPC2132, you can find it on the Philips site.
The manual tells:
Warning: use read-modify-write operation when accessing PINSEL2 register. Accidental write of 0 to bit 2 and/or bit 3 results in loss of
debug and/or trace functionality! Changing of either bit 4 or bit 5 from
1 to 0 may cause an incorrect code execution!
The same manual shows in Table 60 that the Reset value of bit 2 isn't 0,
the default value is the inverted level that is at P1.26 (RTCK) during Reset. This P1.26 needs to be low during reset if you want to use the JTAG port. This will result in setting bit 2 of PINSEL2. If you clear this bit then it will disable the JTAG port.
Regarding your code:
I think your line of code isn't doing what you want it to do.
You are 'anding' PINSEL2 with 0 because the both (0 << #) items will evalute to 0. If you want to clear a bit then you have to 'AND' with the
inverted bitvalue to prevent the changing of the other bits . (I think it should be something like ~(1<<2)
Aalt
>  > Hello Søren,
> following:
>  > 1:0 Reserved.
>  > 6:31 Reserved.
>  > Hope this helps,
>  > Aalt
> > /Søren
> YAHOO! GROUPS LINKS
Aalt Lokhorst
Duinkerkenstraat 21
9723 BN Groningen
P.O. Box 5225
9700 GE Groningen
The Netherlands
Tel: +31-50-5877877
Fax: +31-50-5877899
2005-08-02 by Jim Parziale
According to this, you're clearing PINSEL2 altogether. Did you mean:
PINSEL2 = (PINSEL2 & (1 << 2) & (1 << 3));
> > Hello Søren,
> following:
> > 1:0 Reserved.
> > 6:31 Reserved.
> > Hope this helps,
> > Aalt
> /Søren
Oops - now I did it ...
Is this what you really meant?
 PINSEL2 = PINSEL2 & ((1 << 2) | (1 << 3));
Even so, this clear all other bits...
> > > Hello Søren,
> > following:
> > > 1:0 Reserved.
> > > 6:31 Reserved.
> > > Hope this helps,
> > > Aalt
> > /Søren
Jim Parziale
Email: nuncio.bitis@...
Malden, MA
2005-08-02 by dsidlauskas1
If yopu want to clear bits 2&3 without changing any of the others do:
PINSEL2 = PINSEL2 & 0xfffffff3;
or
PINSEL2 &= 0xfffffff3;
Dave S.
wrote:
> > > > Hello Søren,
shows the
> > > following:
> > > > 1:0 Reserved.
> > > > 6:31 Reserved.
> > > > Hope this helps,
> > > > Aalt
and 3
> > > /Søren
> Jim Parziale
> Email: nuncio.bitis@g...
> Malden, MA
2005-08-03 by Dave
--- In lpc2000@yahoogroups.com, "soren_t_hansen" <soren_t_hansen@y...>
> > Hello S�ren,
> following:
> > 1:0 Reserved.
> > 6:31 Reserved.
> > Hope this helps,
> > Aalt
> /S�ren
You obviously meant:
#define PIO_PINSEL0        ((volatile unsigned long *) 0xE002C000)
#define PIO_PINSEL1        ((volatile unsigned long *) 0xE002C004)
#define PIO_PINSEL2        ((volatile unsigned long *) 0xE002C014)
struct PINSEL_REGS {
	volatile unsigned long* sel0;
	volatile unsigned long* sel1;
	volatile unsigned long* sel2;
static const struct PINSEL_REGS pinsel_regs = {
	PIO_PINSEL0,
	PIO_PINSEL1,
	PIO_PINSEL2
static const struct PINSEL_REGS* pioGetPinSel(void) { return
&pinsel_regs; }
	unsigned long regVal;
	const struct PINSEL_REGS* pinsel = pioGetPinSel();
	regVal = *pinsel->sel2;
	regVal &= ~(PINSEL2_ENABLE_TRACE | PINSEL2_ENABLE_DEBUG);
	*pinsel->sel2 = regVal;
Dave
2005-08-03 by soren_t_hansen
This is the code that I've been trying now, but still it crashes.
PINSEL2 = (PINSEL2 & ~(1 << 2)) & ~(1 << 3);
But I'll just leave it be since if I don't do anything it works ok :o)
/Søren
> Hello Soren,
Philips site.
> The manual tells:
from
isn't 0,
So this actually means that I can't use these pins at the same time as
the JTag interface? Seems that I need to have a little chat with the
guys who made the requirements for this assignment :o)
Thank you very much for the clarification
/Søren
2006-03-15 by upanie1
> 14:04:44 -0000:
cycle.
problem?
> 42Bastian Schick
Hi. Ihave the same problem.
OK, but how to this if i can't load new program - JTAG doesn't want to
work. I can't use ISP because my hardware does not allow to do it.
And one more thing: user manual says that one can't write 1s at
specified position to PINSEL2 but i write 0 to it and JTAG crashes.
please help
Adam
2006-03-15 by German Ortiz
Hi!
If you write PINSEL2 bit 2 to zero, this disable the debug resource on the
LPC microcontroller. So, if you need to debug yor firmware, this bit
PINSEL2:2 must be 1, to ensure the P1.31-26 are enabled as debug port.
I hope this help!
Regards!
German
To: <lpc2000@yahoogroups.com>
Sent: Wednesday, March 15, 2006 8:40 AM
Subject: [lpc2000] Re: PINSEL2 crashes everything
> > 14:04:44 -0000:
> cycle.
> problem?
> > 42Bastian Schick
> please help
> Adam
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.1.385 / Virus Database: 268.2.2/280 - Release Date: 13/03/2006
2006-03-15 by Stanley Frederickson
When you say that your hardware doesn't support ISP, I
am guessing you just don't have the UART setup to
communicate with the PC.  Can you still pull pin P0.14
low during reset to have the chip enter bootloader
mode anyway?  If so, your code that disabled the JTAG
interface won't get to run (the Philips ISP bootloader
will run instead) and then you can connect through the
JTAG interface and reprogram the chip.
Did you also write 0 to bit 2?  If so, this would
switch the JTAG pins into GPIO mode instead of debug
mode.
> allow to do it.
> write 1s at
> and JTAG crashes.
Do You Yahoo!?
http://mail.yahoo.com
2006-03-15 by Adam Malinowski
Thanks. I used P0.14 to get rid of my program
and reprogramed it via JTAG.
Smart idea. Thanks again.
Adam
> mode.
> > allow to do it.
> > write 1s at
> > and JTAG crashes.
> Do You Yahoo!?
> SPONSORED LINKS
> Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=mfaAujKZXA2Z_vxre9sGnQ>
> 	Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=9jjd2D3GOLIESVQssLmLsA>
> 	Intel microprocessors
> <http://groups.yahoo.com/gads?t=ms&k=Intel+microprocessors&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=OMnZuqMZX95mgutt4B-tDw>
> Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microcontrollers&w2=Microprocessor&w3=Intel+microprocessors&w4=Pic+microcontrollers&c=4&s=95&.sig=Malspbd0T4Rq3M4Q0nHrfw>
> YAHOO! GROUPS LINKS
