From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com] On Behalf Of
Lee, Ron
Sent: Tuesday, August 16, 2005 11:23 PM
To: lpc2000@yahoogroups.com
Subject: RE: [lpc2000] OT: Voltage regulator (TO-252)
Hi Lasse.
What's your input voltage and current requirements? National has a series
of LDOs that should work, but they are in a SOT-23 5 pin package. The
LP39xx series have a maximum input voltage of about 6 volts and can supply
around 150 to 300mA. The LP29xx has a maximum input voltage of 16 volts and
the quiescent current varies greatly with the load as you can see below.
Quiescent current
LP3985 - 140 to 200uA (1 to 150mA output)
LP3981 - 170 to 210uA (1 to 300mA output)
LP2985 - 75 to 2500uA (1 to 150mA output)
LP2992 - 75 to 4000uA (1 to 250mA output)
Ron
________________________________________
Lasse Madsen
Sent: Tuesday, August 02, 2005 5:06 PM
To: AVR-Chat@yahoogroups.com; lpc2000@yahoogroups.com
Subject: [lpc2000] OT: Voltage regulator (TO-252)
Hi All,
I have a problem and maybe you can help me.
I've designed a board with two LM1117 LDO regulators which are set to 3.3V
and 1.8V they work fine... except that they both draw 5.1mA in quiescent
current which makes my battery driven application useless... (I know it is
stated in the datasheet but I didn't think when I made the decision to use
it)
The housing for these monsters are TO-252 arranged in this way:
Pin:
3 Voltage input
2 Voltage output
1 Adjust pin
Where pin 2, is the tap and the footprint is viewed from above.
I will never draw more than 75mA in my application on the 3.3V rail and
about 5mA on the 1.8V rail
If you've heard of any regulator with a lower quiescent current please speak
up I've been searching the net for hours now but unable to find anything...
Even a leaded TO92 style regulator would be fine as I'm desperate...
Best regards
Lasse Madsen
SPONSORED LINKS
Microcontrollers
Microprocessor
Intel microprocessors
Pic microcontrollers
8085 microprocessor
YAHOO! GROUPS LINKS
* Visit your group "lpc2000" on the web.
* To unsubscribe from this group, send an email to:
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
_____
YAHOO! GROUPS LINKS
* Visit your group "lpc2000 <http://groups.yahoo.com/group/lpc2000> "
on the web.
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
