Lpc2000
Interrupt Eclipse
Interrupt Eclipse
2005-08-09 by flying_wookie1
Hello all,
I am trying to build one of the examples from the hitex book (keil has
the code examples) on the eclipse development environment.  When I
compile with the keil IDE, the nested interrupt example and download
it, the code runs correctly.... When I modify Lynchzillas tutorial
code to use the timer interrupt and flash an LED, just as in the keil
examples, nothing happens..  I have included the code for my example..
Could anyone spot what is incorrect with the eclipse code? Am I
setting up the linker correctly?
Any help appreciated.
PS sorry about the copy and paste, yahoo groups does not allow file
attachments. :(
               Function declarations
                  Header files
#include "LPC213x.h"
#include "serial.h"
                  Global Variables
volatile int timeval	= 0;
volatile int SecondCnt	= 0;
void Initialize(void);
void init_timer (void);
void feed(void);
void IRQ_Routine (void)   __attribute__ ((interrupt("IRQ")));
void FIQ_Routine (void)   __attribute__ ((interrupt("FIQ")));
void SWI_Routine (void)   __attribute__ ((interrupt("SWI")));
void UNDEF_Routine (void) __attribute__ ((interrupt("UNDEF")));
void tc0 (void)   __attribute__ ((interrupt("IRQ")));
                       MAIN
int	main (void)
	// Initialize the system
	Initialize();
	IODIR1 = 0x00FF0000;
	//IOSET1 = 0x00010000;
	//IOCLR1 = 0x00FF0000;
	while (1)
		if ((SecondCnt & 1) == 0)
		else
			IOSET1 = 0x00FF0000;
                      Initialize
// Setup the Timer Counter 0 Interrupt
  T0MR0 = 1499;                               // 0.1mSec = 1.500-1 counts
  T0MCR = 3;                                  // Interrupt and Reset
on MR0
  T0TCR = 1;                                  // Timer0 Enable
  VICVectAddr0 = (unsigned long)tc0;          // set interrupt vector in 0
  VICVectCntl0 = 0x20 | 4;                    // use it for Timer 0
Interrupt
  VICIntEnable = 0x00000010;                  // Enable Timer0 Interrupt
#define PLOCK 0x400
	// 				Setting the Phased Lock Loop (PLL)
	// Keil MCB2130 has a 12.0000 mhz crystal
	// We'd like the MCB2130 to run at 60.0000 mhz (has to be an even
multiple of crystal)
	// According to the Philips LPC2138 manual:   M = cclk / Fosc	where:
M    = PLL multiplier (bits 0-4 of PLLCFG)
	//																		cclk = 60000000 hz
	//																		Fosc = 12000000 hz
	// Solving:	M = 60000000 / 12000000 = 5
	//			M = 5
	//			Note: M - 1 must be entered into bits 0-4 of PLLCFG (assign 4 to
these bits)
	// The Current Controlled Oscilator (CCO) must operate in the range
156 mhz to 320 mhz
	// According to the Philips LPC2138 manual:	Fcco = cclk * 2 * P
where:	Fcco = CCO frequency
	//																			cclk = 53236800 hz
	//																			P = PLL divisor (bits 5-6 of PLLCFG)
	// Solving:	Fcco = 60000000 * 2 * P
	//			P = 2  (trial value)
	//			Fcco = 60000000 * 2 * 2
	//			Fcc0 = 240000000 hz    (good choice for P since it's within the
156 mhz to 320 mhz range
	// From Table 20 (page 32) of Philips LPC2138 manual    P = 2, PLLCFG
bits 5-6 = 1  (assign 1 to these bits)
	// Finally:      PLLCFG = 0  01  00100  =  0x24
	// Final note: to load PLLCFG register, we must use the 0xAA followed
0x55 write sequence to the PLLFEED register
	//             this is done in the short function feed() below
	// Setting Multiplier and Divider values
  	PLLCFG	= 0x24;
  	feed();
	// Enabling the PLL */
	PLLCON	= 0x1;
	feed();
	// Wait for the PLL to lock to set frequency
	while(!(PLLSTAT & PLOCK)) ;
	// Connect the PLL as the clock source
	PLLCON=0x3;
	feed();
	// Enabling MAM and setting number of clocks used for Flash memory
fetch (4 cclks in this case)
	MAMCR	= 0x2;
	MAMTIM	= 0x4;
	/* Initialize MEMAP - re-map vector table to RAM */
	MEMMAP	= 0x02;
	// Setting peripheral Clock (pclk) to System Clock (cclk)
	VPBDIV=0x1;
	//VPBDIV=0x0; //MCB2100 serial port demo works with this setting
	//init_serial();
	init_timer();
void feed(void)
  PLLFEED=0xAA;
  PLLFEED=0x55;
/*  Stubs for various interrupts (may be replaced later)  */
/* Timer Counter 0 Interrupt executes each 10ms @ 60 MHz CPU Clock */
void tc0 (void)
  ++timeval;
  if ((timeval % 10000) == 0)
    timeval = 0;
    SecondCnt++;
  T0IR        = 1;                            // Clear interrupt flag
  VICVectAddr = 0;                            // Acknowledge Interrupt
	while (1) ;
	while (1) ;
	while (1) ;
	while (1) ;
	crt.s						STARTUP  ASSEMBLY  CODE
	Module includes the interrupt vectors and start-up code.
/* Stack Sizes */
.set  UND_STACK_SIZE, 0x00000004		/* stack for "undefined instruction"
interrupts is 4 bytes  */
.set  ABT_STACK_SIZE, 0x00000004		/* stack for "abort" interrupts is 4
bytes                  */
.set  FIQ_STACK_SIZE, 0x00000004		/* stack for "FIQ" interrupts  is 4
bytes         			*/
.set  IRQ_STACK_SIZE, 0x00000080		/* stack for "IRQ" normal interrupts
is 4 bytes    			*/
.set  SVC_STACK_SIZE, 0x00000004		/* stack for "SVC" supervisor mode
is 4 bytes  				*/
/* Standard definitions of Mode bits and Interrupt (I & F) flags in
PSRs (program status registers) */
.set  MODE_USR, 0x10            		/* Normal User Mode 										*/
.set  MODE_FIQ, 0x11            		/* FIQ Processing Fast
Interrupts Mode 						*/
.set  MODE_IRQ, 0x12            		/* IRQ Processing Standard
Interrupts Mode 					*/
.set  MODE_SVC, 0x13            		/* Supervisor Processing Software
Interrupts Mode 			*/
.set  MODE_ABT, 0x17            		/* Abort Processing memory
Faults Mode 						*/
.set  MODE_UND, 0x1B            		/* Undefined Processing Undefined
Instructions Mode 		*/
.set  MODE_SYS, 0x1F            		/* System Running Priviledged
Operating System Tasks  Mode	*/
.set  I_BIT, 0x80               		/* when I bit is set, IRQ is
disabled (program status registers) */
.set  F_BIT, 0x40               		/* when F bit is set, FIQ is
.text
.arm
.global	Reset_Handler
.global _startup
.func   _startup
_startup:
# Exception Vectors
_vectors:       ldr     PC, Reset_Addr
                ldr     PC, Undef_Addr
                ldr     PC, SWI_Addr
                ldr     PC, PAbt_Addr
                ldr     PC, DAbt_Addr
                nop							/* Reserved Vector (holds Philips ISP
checksum) */
                ldr     PC, [PC,#-0xFF0]	/* see page 71 of "Insiders
Guide to the Philips ARM7-Based Microcontrollers" by Trevor Martin  */
                ldr     PC, FIQ_Addr
Reset_Addr:     .word   Reset_Handler		/* defined in this module below  */
Undef_Addr:     .word   UNDEF_Routine		/* defined in main.c  */
SWI_Addr:       .word   SWI_Routine			/* defined in main.c  */
PAbt_Addr:      .word   UNDEF_Routine		/* defined in main.c  */
DAbt_Addr:      .word   UNDEF_Routine		/* defined in main.c  */
IRQ_Addr:       .word   IRQ_Routine			/* defined in main.c  */
FIQ_Addr:       .word   FIQ_Routine			/* defined in main.c  */
                .word   0					/* rounds the vectors and ISR addresses
to 64 bytes total  */
# Reset Handler
Reset_Handler:
				/* Setup a stack for each mode - note that this only sets up a
usable stack
				for User mode.   Also each mode is setup with interrupts initially
disabled. */
    			ldr   r0, =_stack_end
    			msr   CPSR_c, #MODE_UND|I_BIT|F_BIT 	/* Undefined Instruction
Mode  */
    			mov   sp, r0
    			sub   r0, r0, #UND_STACK_SIZE
    			msr   CPSR_c, #MODE_ABT|I_BIT|F_BIT 	/* Abort Mode */
    			mov   sp, r0
    			sub   r0, r0, #ABT_STACK_SIZE
    			msr   CPSR_c, #MODE_FIQ|I_BIT|F_BIT 	/* FIQ Mode */
    			mov   sp, r0
   				sub   r0, r0, #FIQ_STACK_SIZE
    			msr   CPSR_c, #MODE_IRQ|I_BIT|F_BIT 	/* IRQ Mode */
    			mov   sp, r0
    			sub   r0, r0, #IRQ_STACK_SIZE
    			msr   CPSR_c, #MODE_SVC|I_BIT|F_BIT 	/* Supervisor Mode */
    			mov   sp, r0
    			sub   r0, r0, #SVC_STACK_SIZE
    			msr   CPSR_c, #MODE_SYS|I_BIT|F_BIT 	/* User Mode */
    			mov   sp, r0
				/* copy .data section (Copy from ROM to RAM) */
                ldr     R1, =_etext
                ldr     R2, =_data
                ldr     R3, =_edata
1:        		cmp     R2, R3
                ldrlo   R0, [R1], #4
                strlo   R0, [R2], #4
                blo     1b
				/* Clear .bss section (Zero init)  */
                mov     R0, #0
                ldr     R1, =_bss_start
                ldr     R2, =_bss_end
2:				cmp     R1, R2
                strlo   R0, [R1], #4
                blo     2b
				/* Enter the C code  */
                b       main
.endfunc
.end
