Lpc2000
www server on Olimex LPC2124
2005-08-23 by Bogdan Teodorescu
On Olimex board (lpc2124 and cs8900a) i want to use a www server for remote
sensor reading. I tryed to use Rowley port of   uIP. FreeRTOS has also a
port but I
was also unable to start the server. Has anyone more luck than me in using
the board
with  a www server ? On board there is also some I2C EEPROM for file storage
but I can not figure
out how to upload files in the EEPROM.
Thanks
All the best, Bogdan
Re: www server on Olimex LPC2124
2005-08-31 by gussabina
for remote
also a
> port but I
in using
> the board
file storage
> Thanks
Hi Bogdan:
I know an engineer who is writing a book about TCP/IP for embedded
systems, and he is developing  the stack based on the LPC2000 family
(specifically using the E2129 Olimex board). His name is Sergio and
you would contact him at (sscaglia at intramarket dot com dot ar).
I hope this help you !
Gus
Re: [lpc2000] Re: www server on Olimex LPC2124
2005-08-31 by Bogdan Teodorescu
Thank you Guss
I allready sent him an e-mail
All the best,
Bogdan Teodorescu
To: <lpc2000@yahoogroups.com>
Sent: Wednesday, August 31, 2005 3:38 AM
Subject: [lpc2000] Re: www server on Olimex LPC2124
> for remote
> also a
>> port but I
> in using
>> the board
> file storage
>> Thanks
> Hi Bogdan:
> Gus
2005-08-31 by Richard
for remote
also a
> port but I
Some questions:
+ Are you using the same board that the FreeRTOS server was tested on?
+ Is the software running, but the WEB server not responding, or is
nothing working.
+ If the board is working, but the WEB server not responding, have
you double checked:
 i/ Correct cabling (point to point of through hub)
 ii/ Compatability of IP address
 iii/ Correct port number settings
+ Did you try the project exactly as downloaded from the FreeRTOS.org
site, or did you make any modifications?
> the board
> with  a www server ?
I just double checked from a clean install, and it worked straight
off.
As described on the uIP WEB site, the WEB pages are built into the
binary image.  There is a script file called 'makefsdata' that
converts the html found in the fs (FileSystem) directory into a
simple flat file system as hard coded C structs.  CGI scripts can
also be created for dynamic data.
The FreeRTOS.org support forum is an active resource for problem
solving.  There is a link on the downloads page of the WEB site.
Richard.
2005-08-31 by t68src
There is a specialized company that is already offering ARM7
optimized TCP/IP stacks and device management/web server software.
Take a look at www.iniche.com for product and platform information.
Will likely also have a demo configuration for the Phytec Philips
2294 based board (with SMSC MAC/PHY) very soon (Keil tools). Hope
this is useful to you guys.
> for remote
has
> also a
> > port but I
me
> in using
> > the board
> file storage
> > Thanks
> Hi Bogdan:
family
and
> Gus
2005-09-01 by Bogdan Teodorescu
Hello
The software seems to run. The IP space is OK (I was able to get an answer
from Ping)
But the www server is not running. I still do not know how to upload www
files to board
memory. The software was Rowleys download. The only change - for the
begining- was
the IP add.
All the best,
Bogdan
Sent: Wednesday, August 31, 2005 11:18 PM
> Hi,
> for remote
> also a
>> port but I
> Some questions:
> nothing working.
> you double checked:
>> the board
>> with  a www server ?
> off.
> Regards,
> Richard.
RE: [lpc2000] Re: www server on Olimex LPC2124
2005-09-01 by Paul Curtis
Bogdan,
Richard has explained to you how the software works and that the file
system is compiled int uIP.  uIP does not have a full web server, you
can't dynamically load files onto the board without writing the software
yourself.  If you run HTTP on the default address, you should see a page
come up no problem.  As the board is responding to pings, the MAC and
PHY are working fine and you have life.  It would be a simple matter to
place a breakpoint on an HTTP request and follow the flow of the code if
you know anything about IP.  If you don't know anything about how TCP or
IP works, then you're in for quite a rough ride.
-- Paul.
> From: Bogdan Teodorescu [mailto:bteo@...]
> Sent: 01 September 2005 06:30
> To: lpc2000@yahoogroups.com
> Subject: Re: [lpc2000] Re: www server on Olimex LPC2124
> Hello
> get an answer
> from Ping)
> upload www
> files to board
> begining- was
> the IP add.
> All the best,
> Bogdan
> From: "Richard" <nospam@...>
> > Hi,
> > for remote
> > also a
> >> port but I
> > Some questions:
> tested on?
> > nothing working.
> > you double checked:
> FreeRTOS.org
> >> the board
> >> with  a www server ?
> > off.
> > Regards,
> > Richard.
> > Yahoo! Groups Links
> Most low income households are not online. Help bridge the
> digital divide today!
> http://us.click.yahoo.com/cd_AJB/QnQLAA/TtwFAA/dN_tlB/TM
