I2C Master Receiver with LPC2294
2005-08-23 by Hogan Chris
I am currently using an LPC2294 in conjunction with a Phytec development board. I am able to use the processor to operate as an I2C Master transmitter, however I have problems when I attempt to operate as Master receiver. The slave device that I am writing to requires a one byte command, in order to describe the data that I want to read. So, when I send this command, everything seems to work. However, when I issue a stop command and then restart the bus and address the slave device to read the data I miss the first 1 to 2 bytes of data. I know that the slave device is working correctly because I can effectively communicate to it with an iPort (I2C Master emulator). I only have problems when I try to read with the LPC, any thoughts? Chris Hogan Electrical Engineer Isothermal Systems Research 2218 N. Molter Rd. Liberty Lake, WA 99019 Phone: (509) 241 - 4583 Fax: (509) 927 - 8260 E-mail: chogan@... <mailto:chogan@...> [Non-text portions of this message have been removed]
