Lpc2000
External Memorey Access with LPC2294
2005-08-26 by klgromann
I use a phytec board phyCORE LPC2294 and have troubles to access the
external SRAM. I use the following initialisation for the EMC :
    PINSEL2 = 0x0E614924;
    BCFG1   = 0x20000403;
I may read/write the RAM without problems, but the the same pattern of
4 Bytes is repeated over the whole address range (0x81000000 -
0x81FFFFFF). It seems that the address lines A2:A23 are not working
correct but I don't have any idea why.
Has anybody seen such a behaviour ?
Any suggestions what I've made wrong ?
Thanks
Klaus
Re: [lpc2000] External Memorey Access with LPC2294
2005-08-26 by Jesper Snedker
Is the EMC module powered up?
/Jesper
To: <lpc2000@yahoogroups.com>
Sent: Friday, August 26, 2005 2:28 PM
Subject: [lpc2000] External Memorey Access with LPC2294
>     BCFG1   = 0x20000403;
> Thanks
> Klaus
Re: External Memorey Access with LPC2294
Sorry for the inconvenience, I had had to search the older messages
before. In msg 5541, Didier had mentioned the correct values for the
phytec board :
PINSEL2 = 0x0FE1 69EC
BCFG1   = 0x2000 0400
I don't know exactly which bits makes the board work now, but it
does :-)
regards
Klaus
> /Jesper
> From: "klgromann" <klaus.gromann@r...>
> >     BCFG1   = 0x20000403;
pattern of
working
> > Thanks
> > Klaus
> > Yahoo! Groups Links
