Busted LPC2214?
2005-08-26 by jensalsig
I use a Olimex LPC2214 board and are having some problems.
When I run this code (see below) I have a few pins that don't "act
normal". When messuring on a working pin I see a square wave with a
duty cycle of ca. 20% and an amplitude of 3.3 V. When I messure on ex.
P0.2 I have the same duty cycle ratio but the voltage is only 200mV.
The defective pins are: P0.2, P0.3, P0.20, P0.27, P0.28 and P0.29.
I have used the Timers, RTC and on-chip other perf. with no trouble...
Code:
int main(void)
pll_init();
GPIO0_IODIR |= 0xffffffff;
GPIO0_IOSET = 0xffffffff;
while(1)
GPIO0_IOCLR = 0xffffffff;
Regards Jens Alsig
