Can I use IAP routines with PLL multiplier other than 1x.
2005-08-27 by lhaddix
Hi, Does anyone know if you can use the IAP routines on an LPC2138 to write the flash while running at crystal x6. I saw a note somewhere that said you had to drop the clock multiplier to 1x to use the IAP, but only prior to a certain version. Has anyone tried this? The Phillips boot loader gives evidence that you must run at 1x because it can't go past 19200 baud with 11.0592mhz. However the IAP routines may not care what the multiplier is and it's just how the bootloader sets up the PLL. Landrum
2005-08-27 by lpc2100_fan
Hello when you boot you can not run ISP from 60 MHz because the autobauding would not work. If you call IAP routines within you program to change Flash contents, it is no problem to run as fast as you want, but please use the frequency you are running at (e.g. 60 MHz) for the call. The actual f is needed to perform programming correctly. If you call IAP and tell the routine you are running at 10 MHz while in reality you are running at 60 MHz, it might program sometimes but it is totally unreliable because it tries to program 6 times faster. hth, Bob --- In lpc2000@yahoogroups.com, "lhaddix" <lhaddix@i...> wrote:
> Hi, > Does anyone know if you can use the IAP routines > on an LPC2138 to write the flash while running > at crystal x6. I saw a note somewhere that said > you had to drop the clock multiplier to 1x to use > the IAP, but only prior to a certain version. > > Has anyone tried this? > > The Phillips boot loader gives evidence that you > must run at 1x because it can't go past 19200 baud > with 11.0592mhz. However the IAP routines may not > care what the multiplier is and it's just how the > bootloader sets up the PLL. > > Landrum
2005-08-27 by Landrum Haddix
Bob, Thanks, that's the answer I was hoping for. I appreciate the prompt and accurate assistance. I need to run14.7456mhz * 4 with pclk 1:1 while updating flash. I need to not miss chars in a serial stream during flashing or lose cycles of a system tick so I have the interrupt vector table and receive ISR in ram so I can continue running while the IAP calls block in the foreground. I assume the IAP can handle periodic interrupts while it is working as long as they save context. Does this all sound reasonable? Have you ever seen source for the IAP routines? Have you ever seen source for the boot loader routines? Have you seen a procedure for replacing the bootloader with a custom version. If a .hex file places code in the bootloader area (while it isn't remapped) will the phillips flash utillity correctly write it? My project includes a requirement to replace the default boot loader code with a version that boots from a different data format (a proprietary RS485 based protocol) so I need to make the 'factory load' while the default ohillips loader is present replace the bootloader so subsequent re-flashings can be done over the 485 link. Landrum Haddix lhaddix@... http://web.qx.net/lhaddix
Landrum, what you describe sounds reasonable though not trivial. While receiving characters, you need to have the int vectors remapped to the SRAM and the ISR itself needs to be in SRAM too. There have been discussions about replacing the bootloader with customized versions but as far as I remember the best argument from Philips was that handling IAP can only be compatible across many devices when one bootloader is always used. Modifying the bootloader has significant risks for reliability of flash programming and I understand that Philips does not want to risk any reliability and may be liability issues. Having the same calling convention even if the bootloader changes is worth a lot for reusability of the code written for the LPC2000 devices. Sometimes I wish the source would be published but I agree that the potential chaos with modified bootloaders is not desirable. Bob --- In lpc2000@yahoogroups.com, Landrum Haddix <lhaddix@i...> wrote:
> Bob, > Thanks, that's the answer I was hoping for. I appreciate the > prompt and accurate assistance. > > I need to run14.7456mhz * 4 with pclk 1:1 while updating > flash. I need to not miss chars in a serial stream during > flashing or lose cycles of a system tick so I have the interrupt > vector table and receive ISR in ram so I can continue running > while the IAP calls block in the foreground. I assume the IAP > can handle periodic interrupts while it is working as long as they > save context. Does this all sound reasonable? > > Have you ever seen source for the IAP routines? > > Have you ever seen source for the boot loader routines? > > Have you seen a procedure for replacing the bootloader > with a custom version. If a .hex file places code in the bootloader > area (while it isn't remapped) will the phillips flash utillity > correctly write it? > > My project includes a requirement to replace the default boot loader > code with a version that boots from a different data format > (a proprietary RS485 based protocol) so I need to make the > 'factory load' while the default ohillips loader is present replace the > bootloader so subsequent re-flashings can be done over the 485 link. > > > Landrum Haddix > lhaddix@i... > http://web.qx.net/lhaddix
Bob, > what you describe sounds reasonable though not trivial. While > receiving characters, you need to have the int vectors remapped to the > SRAM and the ISR itself needs to be in SRAM too. I've gotten this part implemented and tested. To get functions in ram I created a new linker section with DATA for ram functions and modified the startup.s to initialize them from the image in the TEXT section. I use the GCC attribute function to place ram functions in that section. To move the vector table I created a section at the start of DATA where the ram vector table is located when not remapped then made the vector table a 'naked' function (no entry/exit code) containing inline assembly for the table that gets relocated into that section. It took some tinkering and staring at the .map and .lst files. I learned more about .ld files than I wanted to know. > There have been discussions about replacing the bootloader with > customized versions but as far as I remember the best argument from > Philips was that handling IAP can only be compatible across many > devices when one bootloader is always used. Modifying the bootloader > has significant risks for reliability of flash programming and I > understand that Philips does not want to risk any reliability and may > be liability issues. I argued the case for keeping the default bootloader and was shot down because it's a marketing requirement that this device flash update in the same manner as our previous products to avoid confusing the installer. I think what I will do is not modify the existing bootloader so that I always have an assured simple way to update the flash and write an additional flash loader that executes in ram, understands the proprietary 485 data and calls the IAP to update the flash. This way the actual flash update would still use the Phillips supplied IAP leaving the flash write details to Phillips. If the flash loader resides in ram it can replace the entire flash including it's own image in the TEXT segment. Talk about spinning plates.<g> Thank you, you have been extremely helpful. The LPC series is fantastic but I've only been climbing the learning curve since March and there are still plenty of mysteries Landrum Haddix lhaddix@... http://web.qx.net/lhaddix
