Lpc2000
LPC2106 Ports (sensitivity to destruction?)
2005-08-26 by Mark Butcher
Hi All
we are using the LPC2106 to read some serial data (among other
things) from an external device (about 5" away via flat band cable
in the same equipment driven by 3V3).
During the development we noticed that a couple of prototypes
stopped working properly and the ports seemed to have been destroyed
(we couldn't toggle them any more). "May be we applied a high
voltage or something we decided and, after changing the chip, forgot
it.
Now we have manufactured about 1000 pieces of equipment and have
been suprised with the high failure rate in the test. From the
errors associated with reading the data from the external chip we
have a high percentage due to failure of ports in the LPC2106 (2..3%
of batch) - either they don't work or we can measure a low impedance
short circuit to ground.
We can assume it is not due to handling because their production is
at a quality production company.
There are a few hundred in the field and we don't know of failures
after leaving the test field...
There are some other errors which we haven't studied in detail which
may be concerned with other ports (used for local bit banging), I'll
know next week once the failure causes are known.
Has any one experience or details about this type of failure or
possible causes? There are no high voltage involved, the chip it
reads data from is 3V3 and required only a few uA so what can be
doing the damage???
Mark Butcher
www.mjbc.ch
Re: [lpc2000] LPC2106 Ports (sensitivity to destruction?)
2005-08-27 by Leon Heller
To: <lpc2000@yahoogroups.com>
Sent: Friday, August 26, 2005 11:17 PM
Subject: [lpc2000] LPC2106 Ports (sensitivity to destruction?)
> Hi All
> it.
> doing the damage???
Something might be happening when you are connecting the units together. I'd
be inclined to put something like 3.3 V Transguards (made by AVX) on all the
lines.
Leon
Checked by AVG Anti-Virus.
Version: 7.0.344 / Virus Database: 267.10.16/83 - Release Date: 26/08/2005
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
Re: LPC2106 Ports (sensitivity to destruction?)
2005-08-27 by Mark Butcher
Hi Leon
The two units are internal to the equipment (simply 2 internal board
connected by flat band) and the two board are never
disconnected/connected.
There are diodes clamping over and under voltage to the 3V3 / 0V rails
(like in most chips to protect inputs).
By the way there was a unit which I measured which was getting quite
hot (not a port issue) and I found that there was a power supply
problem and the LPC2106 was getting 7V8 instead of 3V3. It was getting
very hot but otherwise the equipment was still worked fine.....(not to
be advised though ;-)  )
Mark
www.mjbc.ch
together. I'd
all the
> lines.
> Leon
