CAN - problem with TX Error Counter
2005-09-08 by miruffer
Hi, I have the LPC-E2294 develpmentboard from olimex. The CAN-controllers work fine, but if I plug off the CAN-cable the CAN-controller should go into bus-off state, after the TX-ERROR Counter reachs 255. The error interrupts works fine and in the "Interrupt and Capture Register" the controller captured the "ACK Slot". I look at the TX Error counter and it will be incremented correctly until it reachs 128. The "error warning interrupt" and the "passive state interrupt" occurs correctly and the bits will be set in ICR. After TX-ERR-CNT reachs 128 the ICR only shows an Bus Error and the TX-ERR-CNT holds its value. When I plug on the bus-cable, the transmission of messages continue correctly and the TX-ERR-CNT will be decremented until 0. Now my question. Why does the controller stops incrementing the TX-ERR-Counter at 128? thanks and regards, miru
