Lpc2000
best way to do SPI
best way to do SPI
2005-09-23 by Gus
Hello,
In your opinion, what is the best way to transfer data between 2 LPC
micros using SPI?
The way I have it now, one is master and other is slave. The slave one
have 1 pin called DATA_READY. When the slave needs to send data to
master, it sets DATA_READY high.
Now the problem is that when the master reads data, it also writes
data at the same time (the way SPI works) How would the slave know
that the SPI transaction is read, write or both.
Gus
Re: best way to do SPI
2005-09-23 by y4krys
It is "always both".  It's up to your protocol to decide which data
stream is "don't care" and when.  Only the master can initiate an
exchange on an SPI bus.
Krys
--- In lpc2000@yahoogroups.com, "Gus" <gus_is_working@y...> wrote:
> Hello,
LPC
> micros using SPI?
one
> Thanks,
> Gus
2005-09-23 by Gus
I know that! My question is what is the best way to do that protocol.
Gus
data
> Krys
> > Hello,
> LPC
> > micros using SPI?
slave
> one
to
writes
know
> > Thanks,
> > Gus
As always, it depends ;-).  Here is what I think:
- first, your slave should listen to be able to receive your master
command data.  Your master wouldn't care much for the data send from
the slave until the end of your frame, when an ack from the slave
would be a good thing to have.
- second, the behaviour of both the master and the slave depends on
your command.
This is a simple scenario.  Many SPI protocols take full advantage
from the fact the data can be sent and received at the same time.
Your slave can, and ususlly shoud, have same data ready for the next
exchange.  If not, perhaps an asynch bus would be a better choice?
I hope it is helpful.  I'd have to know much more about your project
to sugest anything more specific.
Krys
protocol.
> Gus
> data
> > Krys
> > > Hello,
2
> > LPC
> > > micros using SPI?
> slave
> > one
> to
> writes
> know
> > > Thanks,
> > > Gus
2005-09-23 by Mark Butcher
I found this works quite well:
SPI interface plus 1 interrupt line from slave to master.
When the master wants to send data it can and the slave is interrupted
by the SPI Rx interrupt.
When the slave wants to send data it interrupts the master via the
interrupt line and waits for the master to collect it.
The transmission may well need a protocol - for example the length of
data followed by the data content.
The other side sends idles (eg. zeros) when there is no data to be
returned (ie. no bidirectional transmission). If it wants, it can then
also send data while receiving.
Generally the SPI on the LPC has to be handled carefully since it has
no FIFO and overruns are hard to detect. I think that it is possible
to set a pattern in the tx register which is automatically sent
(repeated) when nothing else is actively returned, and this can be
used (with a slightly more complicated protocol) to cause the master
side to wait until the slave is actually ready to receive the data.
My philiosphy due to these compilications is to keep transmissions as
short as possible (max transmission speed) and handle reception in a
loop until complete and not handle each byte by individual interrupt
(assuming the transmissions are irregular short bursts and not
continuous.
Mark Butcher
www.mjbc.ch
2005-09-23 by lpc2100_fan
hi,
because the SPI does not have a FIFO, it might be a great idea to use
the SSP, which has FIFOs. Switching between master and slave mode is
tricky in SSP but otherwise highly recommended to use the SSP.
Bob
> continuous.
> Regards
> Mark Butcher
> www.mjbc.ch
2005-09-23 by Gus
This is almost what I have. I think what I am doing is not wrong
then :)
thanks to all who answered
Gus
interrupted
of
then
has
possible
master
as
a
interrupt
> continuous.
> Regards
> Mark Butcher
> www.mjbc.ch
