Lpc2000
Global Variables
Global Variables
2005-09-25 by lehighuboy
The following question involves an LPC2129 and Keil ARM IDE, AA and
CARM compiler.
Are global variables defined in the startup.s file? And, if that's
correct, then where should the code be placed? Finally, how would you
define a global float, unsigned int, char, and const char variables?
(please respond with examples)
Thank you for your help!
Re: [lpc2000] Global Variables
2005-09-25 by Anton Erasmus
> CARM compiler.
Why would you want to define global variables in the startup.s file ?
Define them as you would when writing normal C code. The only thing
the startup.s file does, is to setup a suitable environment for the C
application to run in, as defined in Standard C.
  Anton Erasmus
A J Erasmus
Re: Global Variables
The code is segmented to several C files by function, and a few
variables are shared across functions. I defined those variables in
the first compiled C file, however the other functions in subsequent
files doesn't see them during the compile. I rather not lump
everything into one file therefore I wanted to define global
variables for all C files.
Thanks, Garrett
and
> > CARM compiler.
you
variables?
file ?
C
> Regards
>   Anton Erasmus
> A J Erasmus
http://www.keilsoftware.com/support/man/docs/ca/ca_ap_startupcode.htm
and
> > CARM compiler.
you
variables?
file ?
C
> Regards
>   Anton Erasmus
> A J Erasmus
Re: [lpc2000] Re: Global Variables
2005-09-25 by balaji cr
Have you tried using 'extern'?
For example in file1.c, you have a global variable
int global_var;
In all other files say file2.c and file3.c, you can
use it as:
extern int global_var;
Google for more help. You may find more info and some
good books too.
Balaji
> function, and a few
> those variables in
> not lump
> define global
> Thanks, Garrett
> Keil ARM IDE, AA
> and
> > > CARM compiler.
> Finally, how would
> you
> const char
> variables?
> the startup.s
> file ?
> environment for the
> C
> > Regards
> >   Anton Erasmus
> > A J Erasmus
Dream is just a dream.  A goal is a dream with a plan and a deadline.
- Harvey Mackay
> everything into one file therefore I wanted to define global variables
> for all C files.
This looks like a C problem, not a LPC2000 specific problem.
If you define a global variable
int foo;
in one C module, and you want to access it from a different module,
then you need to define
extern int foo;
in the other module. This is standard C.
I suggest that you buy a book on C programming. If you are still struggling
with basic C concepts, then writing C for an embedded processor is going
to catch you out at some point. Just do not buy anything written by Herbert Schildt.
"Kernighan and Ritchie, The C Programming Language, 2nd Edition" is a good
book to get.
  Anton
> Thanks, Garrett
> --- In lpc2000@yahoogroups.com, "Anton Erasmus" <antone@s...> wrote: >
> On 25 Sep 2005 at 4:11, lehighuboy wrote: > > > The following question
> involves an LPC2129 and Keil ARM IDE, AA and > > CARM compiler. > > >
> > Are global variables defined in the startup.s file? And, if that's >
> you > > define a global float, unsigned int, char, and const char
> variables? > > (please respond with examples) > > > > Thank you for
> your help! > > > Why would you want to define global variables in the
> startup.s file ? > Define them as you would when writing normal C
> code. The only thing > the startup.s file does, is to setup a suitable
> environment for the C > application to run in, as defined in Standard
> C. > > Regards >   Anton Erasmus > -- > A J Erasmus
> --------------------~--> Fair play? Video games influencing politics.
> Click and talk back!
> http://us.click.yahoo.com/T8sf5C/tzNLAA/TtwFAA/dN_tlB/TM
A J Erasmus
Sorry for the simple question. Everything works, thanks.
--- In lpc2000@yahoogroups.com, balaji cr <balaji_c_r@y...> wrote:
> Hi,
> int global_var;
> use it as:
> good books too.
> Cheers,
> Balaji
> > function, and a few
> > those variables in
> > not lump
> > define global
> > Thanks, Garrett
> > Keil ARM IDE, AA
> > and
> > > > CARM compiler.
> > Finally, how would
> > you
> > const char
> > variables?
> > the startup.s
> > file ?
> > environment for the
> > C
> > > Regards
> > >   Anton Erasmus
> > > A J Erasmus
deadline.
> - Harvey Mackay
RE: [lpc2000] Re: Global Variables
2005-09-26 by David Hawkins
> > for all C files.
It is generally good practice not to use global variables anywhere,
unless performance of the application is critical. Instead, where
multiple functions are required to access variables, put them in
a file by themselves, or in the case where another file needs
access to a variable, provide accessors; i.e., set and get functions.
Interrupt service routines are a good example of where a global
might need to be accessed.
eg.
  So you might write code separated into files like:
  /* event_flags.h */
  extern int event_flag;
  /* event_flags.c */
  int event_flag = 0;
  /* isrs.c */
  void my_isr(void)
     event_flag = 1;
however, a cleaner approach is:
  /* event_flags.h */
  void event_flag_set();
  void event_flag_clr();
  /* event_flags.c */
  static int event_flag = 0;
  void event_flag_set() {event_flag = 1;}
  void event_flag_clr() {event_flag = 0;}
  /* isrs.c */
  void my_isr(void)
     event_flag_set();
Think of this solution as writing a C++ class using C.
The static values needed between functions are like member
functions of a class, and the API presented to the user are
like C++ member functions.
Another good example is accessing peripherals, its better
to write an API for accessing the peripheral and then
use that in your code, rather than always accessing
the registers of the peripherals directly. It makes code
more easily portable.
Dave
sorry, that should read 'member variables'
Dave
