Lpc2000
LPC2214: D16-D31 pins available as user I/O?
Re: [lpc2000] LPC2214: D16-D31 pins available as user I/O?
2005-09-25 by Richard Duits
Yes, you can use D16 - D31 as GPIO if you use only 16 bits as data bus.
You can also use some address pins as GPIO if you do not need a large
external address space.
All this is explained in Chapter 8: PIN CONNECT BLOCK of the User Manual
(http://www.semiconductors.philips.com/acrobat/usermanauls/UM_LPC2114_2124_2212_2214_2.pdf).
The data and address bus are configured with the PINSEL2 register.
Richard Duits
skymab wrote:
> Hi,
> are the Pins D16 - D31 available as user I/O while my external memory
> interface is enabled as configured as 16Bit interface?
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
