Flash Utility ISP on LPC2138
2005-09-25 by radim100
Hi I have a board with LPC2132 MCU . ISP Version 2.2.2. works fine at all speeds . When I switch on the same board to LPC2138 ( same crystal 14.7456MHz , same board ) I am having download file problems . Switching back and to LPC2132 works fine . After putting LPC2138 ( different piece of chip ) on again it has similar download problems ( even at slow speed like 9600,4800 ) . Only difference I can see is Bootloader ID . Which is on LPC2132 2.0 and on LPC2138 2.11 . IS this problem in Flash Utility or in LPC2138 ? Thanks for suggestions. Radim
