LPC2101/02/03 Datasheet
2005-09-26 by philips_marketing_usa
The datasheet for the LPC2101/02/03 can be found at; www.standardics.philips.com/products/lpc2000/pdf/lpc2101_2102_2103.pdf See Message number #9057 for the Press Release. http://groups.yahoo.com/group/lpc2000/message/9057
2005-09-26 by Joel Winarske
This works better: www.standardics.philips.com/products/lpc2000/pdf/lpc2101_2102_2103.pdf
2005-09-27 by Richard
Hi Philips Marketing, For the benefits of the 3rd party tool vendors (which ultimately benefits Philips), how about releasing some sort of standard header file description files for these new devices? It can be XML, header files for some compilers, whatever. Clearly the data is available internal at Philips (from the chip designers to doc writers to testers etc.), it would go a long way for us 3rd party tool vendors to support the devices quickly if Philips provides such files. You may of course contact me directly with the files. I would love to add them to our next release. Thanks. At 10:34 AM 9/26/2005, philips_marketing_usa wrote: >The datasheet for the LPC2101/02/03 can be found at; > >www.standardics.philipa.com/products/lpc2000/pdf/lpc2101_2102_2103.pdf > >See Message number #9057 for the Press Release. >http://groups.yahoo.com/group/lpc2000/message/9057 > // richard (This email is for mailing lists. To reach me directly, please use richard at imagecraft.com)
2005-09-29 by radoslaw_mitura
The block diagram in the pdf shows "GENERAL PURPOSE GPIO" mapped to "P0[31:0]" as well as "HIGH SPEED GENERAL PURPOSE GPIO" mapped to the same "P0[31:0]". Does it mean the pins can be connected and controlled by block connected to ARM memory bus or APB bus?
2005-09-29 by philips_apps
Hi, the answer is YES, all of the above. The pins are connected to the APB bus by default for compatibility reasons but can be connected to the Local Bus (memory bus) as well. For the "how" you could check the Users Manual of the LPC2148, which is the first of the Philips devices to use this methode. Robert --- In lpc2000@yahoogroups.com, "radoslaw_mitura" <radoslaw_mitura@y...> wrote: > The block diagram in the pdf shows "GENERAL PURPOSE GPIO" mapped to > "P0[31:0]" as well as "HIGH SPEED GENERAL PURPOSE GPIO" mapped to the > same "P0[31:0]". Does it mean the pins can be connected and controlled > by block connected to ARM memory bus or APB bus?
2005-09-30 by Richard Duits
Hi, Is it possible to read pins with IO0PIN register even is they are mapped to other functions than the GPIO? As far as I know, this is not possible with the LPC2292. With the exception of the ADC pins, I don't know why the pins cannot always be connected to the IO0PIN register. This would be very usefull with reading the state of capture or interrupt pins for example. Richard Duits philips_apps wrote:
> Hi, > > the answer is YES, all of the above. The pins are connected to the APB > bus by default for compatibility reasons but can be connected to the > Local Bus (memory bus) as well. For the "how" you could check the > Users Manual of the LPC2148, which is the first of the Philips devices > to use this methode. > > Robert > > --- In lpc2000@yahoogroups.com, "radoslaw_mitura" > <radoslaw_mitura@y...> wrote: > > The block diagram in the pdf shows "GENERAL PURPOSE GPIO" mapped to > > "P0[31:0]" as well as "HIGH SPEED GENERAL PURPOSE GPIO" mapped to the > > same "P0[31:0]". Does it mean the pins can be connected and > controlled > > by block connected to ARM memory bus or APB bus? > > > > > ------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > * Visit your group "lpc2000 > <http://groups.yahoo.com/group/lpc2000>" on the web. > > * To unsubscribe from this group, send an email to: > lpc2000-unsubscribe@yahoogroups.com > <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/>. > > > ------------------------------------------------------------------------ >
2005-09-30 by lp2000c
I strongly second the request. Not being able to directly read the state of Input Capture and Interrupt pins is a major hassle. If this has not already been done, please consider this for future enhancements. --- In lpc2000@yahoogroups.com, Richard Duits <yahoo@r...> wrote: > Hi, > > Is it possible to read pins with IO0PIN register even is they are mapped > to other functions than the GPIO? As far as I know, this is not possible > with the LPC2292. With the exception of the ADC pins, I don't know why > the pins cannot always be connected to the IO0PIN register. This would > be very usefull with reading the state of capture or interrupt pins for
> example. > > Richard Duits >
2005-10-13 by philips_marketing_usa
Hello Richard, In response to your suggestion (and others'), we have prepared a general Header File for the LPC214x family. I have posted it in the Files section. We will also work on an LPC2101/2/3 file in the near future. Thank you for your feedback. --- In lpc2000@yahoogroups.com, Richard <richard-lists@i...> wrote: > > Hi Philips Marketing, > For the benefits of the 3rd party tool vendors (which ultimately benefits > Philips), how about releasing some sort of standard header file description > files for these new devices? It can be XML, header files for some > compilers, whatever. Clearly the data is available internal at Philips > (from the chip designers to doc writers to testers etc.), it would go a > long way for us 3rd party tool vendors to support the devices quickly if > Philips provides such files. > > You may of course contact me directly with the files. I would love to add > them to our next release. > > Thanks. > > At 10:34 AM 9/26/2005, philips_marketing_usa wrote: > > >The datasheet for the LPC2101/02/03 can be found at; > > > >www.standardics.philipa.com/products/lpc2000/pdf/lpc2101_2102_2103.p df > > > >See Message number #9057 for the Press Release. > >http://groups.yahoo.com/group/lpc2000/message/9057 > > > > // richard (This email is for mailing lists. To reach me directly, please > use richard at imagecraft.com) >
