>Charles,
>If SPI only does 8-bit, why are there option bits in the Control
>Register (S0SPCR) to send and recieve 8, 9, 10,11,12,13,14,15,16
>bits of data? The user manual pretty clearly indicates that the SPI
>is capable of this operation.
>Did I miss something? I don't see any "*" to indicate the option is
>only available on some parts of the family?
>FYI, My real target processor is the LPC2141, but I am doing this
>development on the LPC2131. According to the user manuals SPI
>description, they look identical.
>I currently have my SSP pins assigned to other functions so I can
>not use them.
>If you could please tell me where you read the SPI will only do 8-
>bits, I would appreciate it.
>Thanks again to everyone for the help
>Dave
>--- In lpc2000@yahoogroups.com, "charlesgrenz" <charles.grenz@s...>
>wrote:
>>Hi, I am not sire about the 2131, but the 2138 has a SPI and SSP.
>The
>>SPI only does 8 bit and the SSP allows from 4 (?) to 16 which is
>>programmable.
>>Charles
>>--- In lpc2000@yahoogroups.com, "drb5599" <dbutler@c...> wrote:
>>>Thanks for the good info guys. I am looking at the assembly
>code
>>>for changing the SPI registers. It's just a couple simple lines:
>>>165: S0SPCR = 0x0C24; // Changed to 12-bits per transfer for
>LCD
>>>format.
>>>0x0000215E 2124 MOV R1,#0x24
>>>0x00002160 4829 LDR R0,[PC,#0x00A4]
>>>0x00002162 7001 STRB R1,[R0,#0x00]
>>>you can see that the assembly code just puts the 0x24 in R1, the
>>>upper byte is gone? Why would it do this? I am using the
>memory
>>>and register watch windows as I step thru this code. It is very
>>>clear to see that the upper byte is just ignored. It's like the
>>>compiler thinks the S0SPCR register is 8-bits instead of 16.
>>>Ah..............
>>>That just made me look in the LPC21xx.h file where:
>>>#define S0SPCR (*((volatile unsigned char *) 0xE0020000))
>>>yes, it is defined as a char so it will only look at the first
>byte.
>>>So I changed the char to short.
>>>NO......it still does not work.????
>>>Yes, I am using a GPIO for SEL. That seems to work fine, I just
>>>can't change the size of the SPI buffer?
>>>-Dave
>>>--- In lpc2000@yahoogroups.com, Rob Jansen <rob@m...> wrote:
>>>>Dave,
>>>>>So I configured the SPI control register to operate in this
>>>>>mode.
>>>>>S0SPCR = 0x0C24;
>>>>>However, when I step thru my code, and look at the S0SPCR
>>>register,
>>>>>it
>>>>>is written with a 0x0424!!!!!!!!!!!!!
>>>>Strange, I tried this on my 2138 and there it all works (to
>say,
>>>writing
>>>>to the register works).
>>>>Should work on the 2131 also.
>>>>I wrote a small program
>>>>(http://www.myvoice.nl/electronics/files/io-test.zip) to read
>and
>>>write
>>>>registers and memory - served me well a few times. typing "w
>>>e0020000
>>>>c24" will write to the memory location and read it back
>>>afterwards.
>>>>Typing "r e0020000" will read the memory. I used this program
>>>myself
>>>>already a few times - as soon as I don't trust the hardware I
>>>start
>>>>poking around in the chip ...
>>>>If writing to the register works, can you singlestep through
>the
>>>>assembly code (that's an istep in ARM AXD) or at least see the
>>>assembly
>>>>code and the CPU registers?
>>>>>Also I am new to LCD's never programmed one before, the
>format
>>>of the
>>>>>data looks really strange. If anybody knows some good
>tricks for
>>>>>interfacing an LCD with a serial interface, I would be
>grateful.
>>>>I checked out the controller spec
>>>>(http://mxhaard.free.fr/spca50x/Doc/LCD/1621.PDF ?) and the
>>>interface
>>>>indeed is a bit strange compared to the I2C displays I am used
>to.
>>>Only
>>>>the command mode uses 12 bits, it you write data to the LCD
>you
>>>should
>>>>switch to 14 bits mode.
>>>>It should however be fairly easy, CS to a GPIO pin, WR to SCK
>and
>>>the
>>>>data pin of the LCD to MOSI. Configure CPOL=1 and CPHA=1 (see
>213x
>>>user
>>>>manual), LSBF=0. This gives SOSPCR = 0x0C6E to send the
>commands
>>>and
>>>>after initialization switch over to 0xE6E for 14 bits to send
>the
>>>first
>>>>4 databits to a given address. Sequential datawrites should
>then
>>>be done
>>>>in 8 bits mode.
>>>>This is why you should use a GPIO pin for the CS line. Sending
>>>commands
>>>>is now like:
>>>> CS = Low, S0SPCR = 0x0C6E, S0SPDR = cmd, wait for SPI
>transfer
>>>>complete, CS = high.
>>>>Data:
>>>> CS = Low, S0SPCR = 0xE6E, SOSPDR = addr/data, wait for SPI
>tr.
>>>>compl, S0SPCR=0x86E, S0SPDR = data/data, wait, (more data), CS
>>>High
>>>>You cannot use SSEL for the CS line, the SSEL line will go
>>>inactive
>>>>between datatransfers.
>>>>Think I still prefer an I2C display, SPI only makes sense if
>you
>>>have a
>>>>larger (graphical) display.
>>>>Good luck,
>>>> Rob
>Yahoo! Groups Links
