EEprom with Flash program bug ?
2005-10-04 by Bruce Paterson
Hi, I've been attempting to use a variant of the "EEprom" flash simulation program posted here by Robert. In ee-write I think I've found a bug, or at least something I don't understand. Apologies if this has come up before; I haven't noticed it. ..... location = ee_locate(); ..... destination = (unsigned int *) ((&ee_buffer[0])+((unsigned int)location & EE_BUFFER_MASK)); source = (unsigned int *) command_ee; for(i=EE_REC_SIZE/4;i>0;i--) *(destination++) = *(source++); //prepare sectors from EE_SEC_L to EE_SEC_H for erase ..... command_iap[0]=51; //copy RAM to flash/eeprom command_iap[1]=(unsigned int) (location & EE_START_MASK); command_iap[2]=(unsigned int) (&ee_buffer[0]); command_iap[3]=EE_BUFFER_SIZE; command_iap[4]=EE_CCLK; iap_entry=(IAP) IAP_LOCATION; iap_entry(command_iap,result_iap); command_iap[0]=56; //compare RAM and flash/eeprom command_iap[1]=(unsigned int) source; command_iap[2]=(unsigned int) destination; command_iap[3]=EE_REC_SIZE; iap_entry=(IAP) IAP_LOCATION; iap_entry(command_iap,result_iap); In above comparison, surely "source" and "destination" are not what we want to compare. Firstly, they both point *after* the relevant areas because we incremented the pointers in the copy earlier, and secondly, they are both RAM pointers, whereas I thought we wanted to compare ROM and RAM ? Suspect it should be something like: source = (unsigned int *) ((&ee_buffer[0])+((unsigned int)location & EE_BUFFER_MASK)); command_iap[0]=56; //compare RAM and flash/eeprom command_iap[1]=(unsigned int) source; command_iap[2]=(unsigned int) location; command_iap[3]=EE_REC_SIZE; iap_entry=(IAP) IAP_LOCATION; iap_entry(command_iap,result_iap); result_ee[0]=result_iap[0]; Cheers, Bruce [Non-text portions of this message have been removed]
