Lpc2000
TO PROGRAM SPARTAN 2 FPGA USING ARM.
2005-10-03 by kumarvdpl
Hi Friends,
I am doing a Jtag Programming for SPARTAN FPGA using ARM.
I just gone over the algoritham of XILINX JTAG programming.
The algoritham is made into a program and just it is toggling of pins.
The hex file for the FPGA is get through the UART and sending as a bit
stream to the FPGA JTAG pins.But my program is not working in the FPGA.
What ever the program i am downloading has no effect.
Does any body tried this features in ARM.
I should make this concept to work out in FPGA.
Any comments over this concept plz post in this group.
with regards,
Rajender
RE: [lpc2000] TO PROGRAM SPARTAN 2 FPGA USING ARM.
2005-10-06 by Gromann, Klaus
Hi Rajender,
        I had also a problem programming a SPARTAN FPGA from a serial
EPROM. The problem there was the bit order on the serial line. The EPROM
sends out the MSBit first while the FPGA wants the LSBit first. So I had
to change the bits in the whole FPGA image before programming it into
the EPROM. Maybe you have a similar problem and it works if you change
all the bits before sending the bytes over the serial line. (Bit 8 =>
Bit 0, Bit 7=> Bit 1 and so on)
regards
Klaus
	From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]
On Behalf Of kumarvdpl
	Sent: Monday, October 03, 2005 12:25 PM
	To: lpc2000@yahoogroups.com
	Subject: [lpc2000] TO PROGRAM SPARTAN 2 FPGA USING ARM.
	Hi Friends,
pins.
a bit
the FPGA.
	with regards,
	Rajender
	YAHOO! GROUPS LINKS
	*	 Visit your group "lpc2000
<http://groups.yahoo.com/group/lpc2000> " on the web.
	*	 To unsubscribe from this group, send an email to:
<mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
	*	 Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service <http://docs.yahoo.com/info/terms/> .
