From: lpc2000@yahoogroups.com [mailto:lpc2000@yahoogroups.com]On Behalf
Of philips_apps
Sent: 05 October 2005 18:16
To: lpc2000@yahoogroups.com
Subject: [lpc2000] Re: LPC2292 in Power Down Mode
Hi Dave,
see below one chapter of an application Note that is still in
progress but should probably help you right now. In particular the
paragraph about pull-ups and the Interrupt inputs / Analog inputs
seems something that could help you to reduce your Power Down values.
Reducing Power Consumption
To reduce current consumption on the 3.3V rail in power-down mode
(let's consider the 144-pin devices):
There are 80 pins with internal pull-ups on Ports 1,2 and 3. These
pull-ups are always active.
Set those pins high or keep them floating before entering power down
mode. If set low, they will consume around 50uA (typical) on each
pin.
Port 0 does not have any internal pull-ups. These pins can be set
low.
In LPC2114/2124/2212/2214/2119/2129/2194/2290/2292/2294 and 2210,
there is leakage current (around 200uA) on External Interrupt/ADC
pins if these pins are pulled higher than 1.8V. External Interrupt
pins will contribute to the leakage irrespective of the pin
configuration. ADC pins will contribute to the leakage only if they
are configured as analog inputs.
Below are some hints which will reduce power consumption.
All the LPC2000 devices have two power saving modes: Idle and Power
down. Please refer to the Power Control section in the System
Control Block chapter in the User Manual.
Enable the MAM if the application is run from the on-chip Flash.
Enabling the MAM will enable various buffers and reduces the number
of Flash fetches thereby reducing power consumption.
Disable unused peripherals using the PCONP register.
The peripherals can run at a lower speed as compared to the ARM7
core frequency. Using the VPBDIV register, the peripherals can run
at either half or one-fourth of the system frequency.
Most embedded applications, terminate with a while(1) loop and they
service interrupts whenever needed. In this case, code is still
constantly fetched from the on-chip Flash and executed which adds to
the power consumption. A better solution would be to switch to the
Idle power saving mode and then wait for interrupts. An interrupt
from a peripheral would then wake the device from Idle mode.
Considerable power savings can be achieved by keeping the ARM7 core
in Idle mode while it is waiting for interrupts.
As mentioned above, Flash fetches adds to power consumption. If the
program is encoded using the Thumb instruction set then with each
Flash fetch eight instructions are fetched instead of four (as
compared to ARM). Thus, the number of Flash fetches could be reduced
by using Thumb code.
On a side note, since the on-chip SRAM controller incorporates a
write-back buffer which holds the last data sent by software to the
SRAM, a dummy write needs to be done before entering idle or power
down mode. Hence, if a variable is updated before entering either
power saving mode, a dummy write to the same variable is necessary.
Please refer to section On-Chip Static RAM (SRAM) in Chapter 1 of
the respective User Manual for more detailed information.
Philips Apps team
--- In lpc2000@yahoogroups.com, "dpbevin2k" <dbevin@s...> wrote:
> Hi all,
> I'm trying to use an LPC2292 in a extremely low power situtation
(i.e.
> the whole board < 0.5mA at 3.3V).
> So far, I've put the 2292 into Power Down mode (I see the
oscillator
> stop) and the board gets down to about 0.8mA.
> I've tried things like:
> - disabling the EMC and making all pins GPIO inputs (0.8mA)
> - disabling the EMC and driving all GPIO pins high (1.6mA)
> - not disabling the EMC with 1M pullups on D0-D15 (2.0mA)
> - disabling the EMC and driving all GPIO pins low (2.8mA)
> NOTE: There are NO peripherals on the memory bus at the minute.
> Does anyone have any ideas as to what I'm doing wrong??? What's the
> best state to leave the 2292 in to acheive the best results?
> Thanking you in advance
> Dave Bevin
Yahoo! Groups Links
Serck Controls Ltd, Rowley Drive, Coventry, CV3 4FH, UK
Tel: +44 (0) 24 7630 5050 Fax: +44 (0) 24 7630 2437
Web: www.serck-controls.com Admin: post@...
A subsidiary of Serck Controls Pty. Ltd. Reg. in England No. 4353634
This email and files transmitted with it are confidential and
intended solely for the use of the individual or entity to whom they
are addressed. If you have received this email in error please notify
the above. Any views or opinions presented are those of the author
and do not necessarily represent those of Serck Controls Ltd.
This message has been checked by MessageLabs
