Disabling interrupts using VICIntEnClear / VICIntEnable
2005-10-05 by smoutpatrick
Hi, to protect a shared data area against simultanous access by an interrupt routine and a main task, I'm using the VICIntEnClear / VICIntEnable registers. I intentionally don't wanna disable all the interrupts because this would cause too much latency for other interrupts. However, due to the pipelined instructions, one cannot guarantee that no interrupt occures just after it was disabled by a write to the VICIntEnClear register. I suppose that I can place a few dummy instructions right after the instruction that writes the VICIntEnClear register to prevent simultanous access but I'm not sure how many clock cycles this delay must be. The technical manual of the PrimeCell Vectored Interruptcontroller mentions a worst case scenario of 13 cycles ( Interrupt synchronization + Worst case Interrupt disabling period). Anyone who can confirm this? Best regards, Patrick Smout
