Lpc2000
Strange data abort problem
2005-10-10 by Joris Hooijberg
Hello all,
While trying to get interrupts to work on a LPC2106 in
Flash we came
along some strange kind of problem.
The code starts up, and starts initializing
interrupts.
In the InitInterrupt() routine we set the functions
the interrupt
vector should point to:
irqVector1 = MyTimerInterrupt;
irqVector0 = DataAbortInterrupt;
We designed the function 'DataAbortInterrupt()' so
that it only prints
the text "Data Abort" on the Hyper Terminal.
The problem is that assigning the interrupt vectors
gives us a "Data
Abort" error on the terminal. The compiler CANT KNOW
where the
irqVector0 is pointing to because DataAbortInterrupt
is assigned after
MyTimerInterrupt.
Can anyone tell us what's happening here? And why doe
we get those anoying Data Aborts at this point... It's
really getting us crazy...
This is how the VIC-handling part of the startup.s
looks:
.section .startup,"ax"
.code 32
.align 0
b start
b irqVector0
b irqVector0
b irqVector0
b irqVector0
b irqVector0
b irqVector1
b irqVector1
@ create a variable to hold a C function pointer to be
called on IRQ
.global irqVector0
irqVector0:
.word 0 @ this should be set to a C function
.global irqVector1
irqVector1:
Joris and Tiemen
Yahoo! Music Unlimited
Access over 1 million songs. Try it free.
http://music.yahoo.com/unlimited/
Re: [lpc2000] Strange data abort problem
2005-10-10 by Sten
Hello,
it is a very strange way to set interrupt vectors...
1) Are you sure that really a "data abort" occurs? All of your "nasty"
vectors pointing to a data abort ISR including undefined instruction,
prefetch abort and SWI!
2) Have you examined where the "data abort" really occurs? If yes: take
a look into assembly code at this position. Data abort only occurs if
you try to access an invalid address (data operand).
3) Where is your vector table located? In RAM or ROM? Why don't you
assign your vectors in your startup file statically?
  Sten
Joris Hooijberg wrote:
> Hello all,
> Flash we came
> interrupts.
> the interrupt
> that it only prints
> gives us a "Data
> where the
> is assigned after
> MyTimerInterrupt.
> looks:
> .code 32
> .align 0
> b start
> b irqVector0
> b irqVector0
> b irqVector0
> b irqVector0
> b irqVector0
> b irqVector1
> b irqVector1
> called on IRQ
> .global irqVector0
> irqVector0:
> .global irqVector1
> irqVector1:
> Thanks,
> Joris and Tiemen
 Do you need a tiny and efficient real time
 operating system (RTOS) with a preemtive
 multitasking for LPC2000 or AT91SAM7?
   http://nanortos.net-attack.de/
 Or some open-source tools and code for LPC2000?
   http://www.net-attack.de/
2005-10-10 by Rob Jansen
Joris, Tiemen,
indeed a strange way to initialize the interrupts.
I've got the same kind of questions as Sten when looking at this code.
If your looking for startup code, have a look at
http://www.myvoice.nl/electronics/files/i2c-test.zip - that contains a
complete application, including startup code.
Main question is why you do your vector initialization like this. There
is a reason for ARM to give us access to all these seperate vectors.
I would indeed specify seperate functions for all the 'nasty' vectors.
If this code is in Flash, not using the mapping of vectors to RAM (using
the MEMMAP register)  you will get a data abort due to writing to flash.
    Rob
> looks:
> .code 32
> .align 0
> b start
> b irqVector0
> b irqVector0
> b irqVector0
> b irqVector0
> b irqVector0
> b irqVector1
> b irqVector1
> called on IRQ
> .global irqVector0
> irqVector0:
> .global irqVector1
> irqVector1:
> Thanks,
> Joris and Tiemen
Re: Strange data abort problem
2005-10-11 by embeddedjanitor
Apart from what others have written about better ways to do this
(using the AIC), I think there is also a problem in the way you have
written the assembler code.
Unfortunately one of the Philips app notes is written this way, but it
is wrong.
> .code 32
> .align 0
> b start
> b irqVector0
> b irqVector0
> b irqVector0
> b irqVector0
> b irqVector0
> b irqVector1
> b irqVector1
> called on IRQ
> .global irqVector0
> irqVector0:
> .global irqVector1
> irqVector1:
  b xxx expects xxx to be actual code, not a "pointer to code"
If you want to use a pointer to code, then you should be doing
  ldr pc,irqVector
That will load the pc with the pointer, essentially a jump to the
code.
As an example of this, consider the code I use for my vectors which
looks like:
	    ldr   pc,v0	 	 	@ reset vector
            ldr   pc,v1	  		@ Undefined Instruction
            ldr   pc,v2	 	 	@ Software Interrupt
            ldr   pc,v3	  		@ Prefetch Abort
            ldr   pc,v4		  	@ Data Abort
            ldr   pc,v5		  	@ reserved
	    ldr   pc,[pc,#-0xF20]	@ IRQ : read the AIC
	    ldr   pc,[pc,#-0xF24]	@ FIQ : read the AIC
v0:	    .long start
v1:	    .long undef_handler
v2:         .long swi_handler
v3:         .long prefetch_abort_handler
v4:	    .long data_abort_handler
v5:	    .long reserved_handler
Here the vectors v0..v5 are predefined constants, but they could
equally well be variable pointers.
2005-10-11 by jorishooijberg
OK, it IS a nasty interrupt table... guilty as charged...
The startup code in here is the same as embeddedjanitor's example.
We changed our startup.s like this:
         .code 32
         .align 0
         LDR PC,[PC,#resetHandlerAddress - . - 8]
         LDR PC,[PC,#undefHandlerAddress - . - 8]
         LDR PC,[PC,#swiHandlerAddress - . - 8]
         LDR PC,[PC,#prefetch_abortHandlerAddress - . - 8]
         LDR PC,[PC,#data_abortHandlerAddress - . - 8]
         NOP
         LDR PC,[PC,#irqHandlerAddress - . - 8]
         LDR PC,[PC,#fiqHandlerAddress - . - 8]
resetHandlerAddress:
  .word start
[etc etc]
irqHandlerAddress:
  .word MyTimerInterrupt
fiqHandlerAddress:
# Reserve memory for exception handlers
        #0x00000020
HandleReset:
[etc etc]
        #0x00000034
HandleIRQ:
        #0x00000038
HandleFIQ:
Running the code gives us A Prefetch error, but the interrupts are
handled correct.
Is seems that the processor doesn't like it when we change the program
counter... Did we forget something?
Anyay, thanks for the help,
Joris
> handled correct.
where i typed Prefetch i meant Data Abort
sorry about that
Joris
2005-10-11 by bdmlpc
--- In lpc2000@yahoogroups.com, "jorishooijberg" <jorishooijberg@y...>
>          .code 32
>          .align 0
>          NOP
>   .word start
> [etc etc]
> irqHandlerAddress:
> fiqHandlerAddress:
>         #0x00000020
> HandleReset:
> [etc etc]
>         #0x00000034
> HandleIRQ:
>         #0x00000038
> HandleFIQ:
> handled correct.
> Joris
Hello Joris,
This is a very complicated way to modify the PC. But this immediate
displacment relative to the PC will only work under certain
circumstances. It is quite dangerous! And the data abort vector is
found correctly? Are you sure?
Do you know at which address this error occur? Just check the link
register R14 and see your assembly code what happens.
  Sten
LPC2106 & CS8900A -- delay needed in Rd/Wr?
2005-10-16 by Michael Anburaj
I have got the CS8900A talking to the LPC2106 in 8bit
mode. Strange things are happening
Without any delay (without additional delay added in
code) in the Rd & Wr cycles, repeated reads result in
random values.
Then I added delay to stretch the RD_low
RD_low
delay
Read_Data
RD_hi
With this I get consistent reads, but the bytes seem
to be swapped.
For instance, when read 0 (ProductID), read from Data0
== 0x63 & Data1 == 0x0e
yields 0x0e63, but it should have been 0x630e
Similarly I get 0xd000 when I read SelfST. With
different delay values I get 0x0000 for SelfST or
0x6363 for ProdID.
Can someone let me know what delays are required &
where, it will be great!
Thanks a lot,
-Mike.
Re: [lpc2000] LPC2106 & CS8900A -- delay needed in Rd/Wr?
2005-10-16 by Richard Duits
I had similar experiences with GPIO and the external memory controller
on a LPC2292. I found out that in this case, it is possible for a read
to start on the external memory controller before a write to the GPIO is
finished. Don't know if this is the same problem because you are only
using GPIO, maybe you are using both port0 and port1???
Try writing the RD_low twice, that way the first write must be finished
before the second can begin, the second write does not change anything,
so the read is occuring when the outputs are in the right state.
Richard Duits
Michael Anburaj wrote:
> Hi,
> random values.
> RD_low
> delay
> Read_Data
> RD_hi
> to be swapped.
> 0x6363 for ProdID.
> Thanks a lot,
> -Mike.
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
