Lpc2000
Confused re: endianness
2005-10-18 by rtstofer
I have a pointer to an unsigned 32 bit value in an array[512] of
unsigned chars (actually the partition table of a CF).  When I point
to the value using GCC, it seems that the code is assuming I am
pointing at the high word and that the low word precedes the high word
in memory.
I think I am pointing at the low word and the high word should follow.
The byte order within the two 16 bit words is correct.
Any thoughts about what I am doing wrong.  I can see the sector dump
and I can see the results of extracting values and the results are
wrong.  Bytes work and 16 bit words work but 32 bit words do not.
Richard
Re: [lpc2000] Confused re: endianness
2005-10-18 by Tom Walsh
>in memory.
You might have a hardware problem where you are byte swapping?  Try
running an IDENTIFY_DRIVE (0xec) command on the CF.  This will send you
back a bunch of bytes structured as:
=============== begin ==================
struct DriveID {
  Word Signature;
  Word NumCylinders;
  Word Reserved1;
  Word NumHeads;
  Word NumUnBytePerTrack;
  Word NumUnBytePerSector;
  Word NumSectorsPerTrack;
  DWord NumberSectorsPerCard;
  Word Reserved2;
  char SerialNumber[20];
  Word BufferType;
  Word BufferSize;
  Word EccBytesPassed;
  char FirmwareRev [8];
  char ModelNumber [40];
  Word Max1SectorRW;
  Word DWnotSupported;
  Word Capabilities;
  Word Reserved3;
=============== end ===================
Try looking at the text string: ModelNumber.  That will tell you if byte
swapping is the problem.
I ran into byte swapping issues between the IDE registers and the Data
register while working with a big-endian controller (MC68EZ328).
IIRC, something tells me that the drive data is Big-Endian on the CF and
IDE drives...
TomW
>Richard
>Yahoo! Groups Links
OLimex laziness?!
2005-10-18 by rseku
The currently released board LPC-P2138 has LED address 0x3000, and
BUTTON a address 0x18000. The schematic shows LED pins on 12,13 what
gives 0x1800 mask, and buttons on 15,16 (really is 16,17)
Welcome any feedback!
robert
RE: [lpc2000] OLimex laziness?!
2005-10-18 by Paul Curtis
> 0x3000, and BUTTON a address 0x18000. The schematic shows LED
> pins on 12,13 what gives 0x1800 mask, and buttons on 15,16
> (really is 16,17)
You're not making any sense.  What's the problem?
Paul Curtis, Rowley Associates Ltd  http://www.rowley.co.uk
CrossWorks for MSP430, ARM, AVR and now MAXQ processors
Re: Confused re: endianness
Try
send you
> struct DriveID {
>   Word Signature;
>   Word NumCylinders;
>   Word Reserved1;
>   Word NumHeads;
>   Word Reserved2;
>   Word BufferType;
>   Word BufferSize;
>   Word Max1SectorRW;
>   Word Capabilities;
>   Word Reserved3;
if byte
Data
CF and
> IDE drives...
> TomW
Yes, for the firmware revision and model ASCII strings the chars are
in big endian word order.  NumberSectorsPerCard is also in big
endian word order.
But, I'm at the next step: reading LBA sector 0.  Here the sector
dump shows the data in little endian word and byte order.  In fact,
when I point a WORD pointer (16 bit) into the buffer, I get the
right answer: LSB MSB in ascending order.
The hangup seems to be when I point a DWORD pointer at some
location.  It picks up those two bytes in ascending order and then
backs up and picks up the two bytes ahead of the pointer as the
MSW.  I was expecting LSW MSW in ascending order where I am pointing
at LSW.  What I get is MSW LSW even though I am pointing at LSW.
Curious!  The bytes are in the proper order.  Alignment issue?
My workaround?  Use something like memcpy to get the data into the
structure.
Richard
Well, it isn't really endianness that causes the glitch, it is
alignment.  The ARM requirement for alignment of, call them half-words
and words, is not consistent with the layout of the various disk
parameter blocks.
Getting from the sector layout to a nice, neat, data structure is
going to be a PITA!
Richard
Re: [lpc2000] Re: Confused re: endianness
2005-10-18 by Richard Duits
If you use an "__attribute__((packed))" structure with GCC, the compiler
assumes it is not aligned and reads everything one byte at a time (even
if it is aligned).
Richard Duits.
> parameter blocks.
> going to be a PITA!
> Richard
> SPONSORED LINKS
> Microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=Microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=tsVC-J9hJ5qyXg0WPR0l6g>
> 	Microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=DvJVNqC_pqRTm8Xq01nxwg>
> 	Pic microcontrollers
> <http://groups.yahoo.com/gads?t=ms&k=Pic+microcontrollers&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=TpkoX4KofDJ7c6LyBvUqVQ>
> 8051 microprocessor
> <http://groups.yahoo.com/gads?t=ms&k=8051+microprocessor&w1=Microprocessor&w2=Microcontrollers&w3=Pic+microcontrollers&w4=8051+microprocessor&c=4&s=93&.sig=1Ipf1Fjfbd_HVIlekkDP-A>
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
compiler
(even
> if it is aligned).
> Richard Duits.
Thanks!  I'll give it a try right now.
Richard
2005-10-19 by rtstofer
> compiler
time
> (even
> > if it is aligned).
> > Richard Duits.
> Richard
Initially I had no success but on reflection I realized the example
was too large to test.
I created a small structure
struct frame {
 unsigned char b;
 unsigned short w; // misaligned
 unsigned int d; // misaligned
} __attribute__ ((packed));
and worked with that.  The __attribute__ does solve my problem.  Now
I need to rework the structures...
Thanks!
Richard
