Lpc2000
Setting EXTPOLAR and EXTMODE bit 0
2005-10-18 by bell_c_d
I'm trying to set EXTINT0 to active-high, edge-sensitive (i.e. set
EXTPOLAR and EXTMODE to 1), but am unable to set/read back bit 0 in
either of the registers.  FWIW, bit 1 (for EXTINT1) sets/reads back
successfully.
The code sample below looks correct.  Does anyone have any ideas?
	byte b=EXTPOLAR;
   	E3A0320E   mov r3, #0xE0000000
   	E283397F   add r3, r3, #0x001FC000
   	E3A02F53   mov r2, #0x0000014C
   	E7D33002   ldrb r3, [r3, r2]
   	E54B300D   strb r3, [r11, #-13]
	EXTPOLAR = 1; // set EXTINT0 active high
   	E3A0220E   mov r2, #0xE0000000
   	E282297F   add r2, r2, #0x001FC000
   	E3A01F53   mov r1, #0x0000014C
   	E3A03001   mov r3, #0x00000001
   	E7C23001   strb r3, [r2, r1]
	b=EXTPOLAR;
	b=EXTMODE;
   	E3A02F52   mov r2, #0x00000148
	EXTMODE = 1; // set EXTINT0 edge-sensitive
   	E3A01F52   mov r1, #0x00000148
	b=EXTMODE;
Re: [lpc2000] Setting EXTPOLAR and EXTMODE bit 0
2005-10-18 by Richard Duits
The EXTMODE and EXTPOLAR have some serious bugs for all but the latest
LPCs. I suggest you look at the errata for the chip you are using.
Richard Duits.
> successfully.
>       byte b=EXTPOLAR;
>       b=EXTPOLAR;
>       b=EXTMODE;
>       b=EXTMODE;
> YAHOO! GROUPS LINKS
>     *  Visit your group "lpc2000
>       <http://groups.yahoo.com/group/lpc2000>" on the web.
>     *  To unsubscribe from this group, send an email to:
>        lpc2000-unsubscribe@yahoogroups.com
>       <mailto:lpc2000-unsubscribe@yahoogroups.com?subject=Unsubscribe>
>     *  Your use of Yahoo! Groups is subject to the Yahoo! Terms of
>       Service <http://docs.yahoo.com/info/terms/>.
Re: Setting EXTPOLAR and EXTMODE bit 0
Thanks, I just found the workaround in the errata.
latest
> Richard Duits.
set
in
back
> > successfully.
> >       byte b=EXTPOLAR;
> >       b=EXTPOLAR;
> >       b=EXTMODE;
> >       b=EXTMODE;
> > YAHOO! GROUPS LINKS
of
Followup- it's still not possible to set bit 0 in EXTMODE/EXTPOLAR
even using the workaround suggested in the errata, but I was able to
workaround this further limitation by setting bits for other EXTINTs
along with bit 0.  I'm only using EXTINT0 but hopefully changing the
polarity of unused interrupts isn't going to mess anything up.
> latest
using.
> > Richard Duits.
> set
0
> in
> back
> > > successfully.
ideas?
> > >       byte b=EXTPOLAR;
> > >       b=EXTPOLAR;
> > >       b=EXTMODE;
> > >       b=EXTMODE;
> > > YAHOO! GROUPS LINKS
Terms
> of
