Lpc2000
C code inline with assembler file output
2005-10-19 by roelof t Hooft
Hi all,
I would like to have the C code combined with the
generated assembler output.
I have these lines in the source code :
//      bcfg0 = 0x2000fbef;
        bcfg0 = ((flash_mw << 28) | (flash_bm << 27) | (flash_wp <<
26) | (flash_wst2 << 11) | (flash_rble << 10) | (flash_wst1 << 5) |
flash_idcy);
The values for the second line are defined in a header file. Now I
want to see the generated hex value. It is there in the corresponding
.lst file, but there's no reference to the source code line that
belongs to it.
How can I make the compiler/assembler/linker include the lines of
source code (in the assembler output) for reference ?
I'm a bit puzzled by the wealth of options offered by the different
programs. I also included the most common, I think, options to no
avail.
TIA
roelof
Re: C code inline with assembler file output
--- In lpc2000@yahoogroups.com, "roelof t Hooft" <roelofh@i...> wrote:
Forgot to mention that I'm using arm-elf-* compiled with
the scripts from rod.info under Debian linux.
roelof
2005-10-19 by bdmlpc
Hello,
just turn on debugging info ('-g') and have a look at your object- or
elf-file with 'arm-elf-objdump -DS <file>'. This will display C-source
and assembler in a mix. Hint: If you turn off optimization ('-O') the
output is more readable!
  Sten
> Hi all,
> flash_idcy);
> belongs to it.
> avail.
> TIA
> roelof
2005-10-19 by rtstofer
--- In lpc2000@yahoogroups.com, "bdmlpc" <list@n...> wrote:
> Hello,
source
>   Sten
^^^ EXCELLENT! ^^^
I decided to get a combined .LST file for every source by using:
CFLAGS  = -I./ -c -fno-common -O0 -g -Wa,-ahls=$*.lst -Wall
Richard
> Hello,
Thank you for responding.
The arm-elf-objdump command generated a whopping 8 MB file
but not with the nessecary debugging information :-(
Unfortunally there seems to be no debugger output in the
.lst file either while in other's there is. No matter
the settings I tried. So I copied the line of source to
be debugged into the file that generated the debug
info in the .lst output and took it from there.
roelof
Re: [lpc2000] Re: C code inline with assembler file output
2005-10-19 by Sten
>>Hello,
> roelof
Did you try to dump the object file only? There should be mix of C
source and assembly output.
arm-elf-gcc -c -o test.c
arm-elf-objdump -DS test.o
   Sten
 Do you need a tiny and efficient real time
 operating system (RTOS) with a preemtive
 multitasking for LPC2000 or AT91SAM7?
   http://nanortos.net-attack.de/
 Or some open-source tools and code for LPC2000?
   http://www.net-attack.de/
2005-10-26 by roelof t Hooft
There is a mix of c code and assembler in an/the output
file, but not the (4) lines of c code I needed.
That is why I put the code in a different source file
which would appear in the output (c/ass. mix) file.
Thanks
roelof
