is IAP possible using ARM Mode..?
2005-10-25 by dhp_ec
hello all,
This is abt Flash Programming,,is onchip flash programming BY USING
IAP, possible in ARM mode.?
i found a flash programming example by using IAP in THUMB Mode in the
group
here it is ...
static void callIAP(void) __attribute((naked));
///// fast way to get the address of flashParams[] directly into r0
register void *pFP asm("r0") = flashParams;
asm volatile(" mov r1, r0\n" // copy &flashParams[] into r1
" bx %[iapLocation]" // 'bx' because IAP is Thumb mode
: "r" (pFP), [iapLocation] "r" (IAP_LOCATION)
: "r1" );
But as IAP is alaways called by a word pointer in register R0
(pointing to RAM),so is this not possble in ARM MOde Right..?
If so then,how can i make changes so that this piece of code works
for ARM mode..?
Am I right or missing something..?Pls suggest
regards
dp
