JTAG Debugger
2005-10-26 by mark_dell555
Hi, I have a Agilent E5900B emulation probe that I've been trying to get working on a LPC2134 with ADS. It works fine on my AT91 dev board, but I cant get it to work in ADS with the LPC2134. Note that this probe is ARM7TDMI not -S. I seem to have some success (RESET, STOP, RUN, and STEP, and poll register etc..) using the telnet interface when I disconnect the RTCK pin. But either way I get alot of Data Aborts in ADS. I was wondering if anyone has experienced this problem? I've read a bit that suggests the problem could be that the probe doesnt support -S, but I'm unsure, especially since using telnet I can get it to function. Also are there any other debuggers that work with this Agilent probe? And my final option is to put togather a wiggler type jtag, and use it. What do you think I should do? Just give up on this Agilent probe? Any help, input, and opinions are welcome. Thank you, Mark
