--- In lpc2000@yahoogroups.com, "eng_amrahmed3000"
<eng_amrahmed3000@y...> wrote:
> Salam,
> I did that but the problem is still exist :-(
> Thanks
> --- In lpc2000@yahoogroups.com, Michael Johnson <mpj@r...> wrote:
> > Hi,
> > Try setting the "Targets | Wiggler | Parallel Port Sharing"
> property to
> > be "Yes".
> > Regards
> > Michael
> > p.s. it may be worth sending CrossWorks support mails to
> > support@r...
> > >Salam Again,
> > >Ok, Debugging is working fine.
> > >But i have encountered a strange behaviour.
> > >When i shut down crossworks and unplug the power supply, Then
> > >connect it again and restart CrossWorks. CrossWorks didn't detect
> > >the Wiggler Interface (20 PIN) unless i restart my PC to Works
> > >again !!!
> > >What is the reason ?
> > >Eng. Amr Ahmed
> > >EGYPT
> > >>THANKS VERY MUCH Michael Johnson
> > >>I have set a breakpoint on the the start of my code and the
> > >>debugging is working very well.
> > >>Eng. Amr Ahmed
> > >>EGYPT
wrote:
> > >>>Hi,
> > >>>Have you set a breakpoint anywhere? The 1.4 release didn't set
> a
> > >>default
> > >>>breakpoint on main - the 1.5 release does.
> > >>>Michael
> > >>>>Salam,
> > >>>>The configuration under project options is "ARM Flash Debug"
> > >>>>What is the problem ?
> > >>>>Thanks for your reply.
> > >>>>Eng. Amr Ahmed
> > >wrote:
> > >>>>>Hi Amr,
> > >>>>>Do you have one of the "Debug" configurations selected
> > >e.g. "ARM
> > >>>>Flash
> > >>>>>Debug".
> > >>>>>Regards
> > >>>>>Michael
> > >>>>>>Salam ALL,
> > >>>>>>I have build Wiggler Interface succesfully.
> > >>>>>>I use CrossWorks for ARM 1.4.
> > >>>>>>I can Compile my codes and choose Start Debugging.
> > >>>>>>The code works ok ( I can see on LEDs )
> > >>>>>>So The interface works perfectly to program and run the code
> > >>>>using JTAG
> > >>>>>>But I can't use Step Into and similar debugging functions !
> > >>>>>>Please I need your help
> > >>>>>>Best Regards,
> > >>>>>>Amr Ahmed
> > >>>>>>Yahoo! FareChase - Search multiple travel sites in one
> > >click.
> > >>>>>>[Non-text portions of this message have been removed]
> > >>>>>>Yahoo! Groups Links
> > >>>>Yahoo! Groups Links
> > >Yahoo! Groups Links
I think after power down/up you have to apply manual Reset to the
board ( that is at least my experience with CrossWorks and wiggler )
Radim.
