timothymarknorton wrote:
>We've just started making the move to Philips ARM7 (LPC213x). I have
>a IAR Kickstart kit and starting my first project with the 32K limit
>compiler. We've been toying with the idea of using the GNU compiler.
>However, from what I've found so far, it looks as though none of the
>free tools allow you to program and debug from flash. Is this correct
>or am I missing something?
With my project, I have an LPC2106 and LPC2138 on the board. I went
with the GNU gcc toolchain running under Linux as the developement
platform. Debug is done with Insight-6.1 (patched for register bug) and
an Abatron BDI2000. I can debug from Flash as the Insight talks with
the BDI2000 and they seem to get on well together.
For programming, having set my config file with the binary name to be
used, I simply open a telnet window to the BDI2000. From there, I type
"erase" and then "prog" to put a new program into Flash. I then reload
the symbols from Insight: "Run | Disconnect", "File | <most recent>",
"Run | Connect" and start working with the new program.
The BDI2000 is pricey, compared with the wigglers, but, I don't have to
worry about if the 0.1uf caps should be on the Wiggler lines, or if my
wires are too long...
TomW
