Lpc2000
Solenoid Control.
Solenoid Control.
2005-11-02 by Nice Guy
I know this is kinda off topic, but I'm having problems controlling a
solenoid.  I want to use a gpio pin to simply turn the solenoid on and
off.  I used a NPN transistor in series with the solenoid to control
it, but the solenoid only has around 2 ohms resistance and the
internal resistance of the transistor must be much higher because most
of the voltage is droped across the transistor instead of the
solenoid.  Could someone recomend a better solution to this problem or
suggest a good place on the web to find info.
Thanks
Re: [lpc2000] Solenoid Control.
2005-11-02 by Robert Adsett
Actually transistors don't really have a resistance drop then have a
voltage drop.  If you are driving it into saturation the drop will be from
0.5V to 1V or even higher depending on the current.  Speaking of current
the low resistance suggests a high current coil (or a shorted coil).
Driving that coil with 3V would give a better than 1Amp draw, can your
power supply support that?  Is the transistor large enough to sink that
much current?  Maybe you just fused the transistor.
For that kind of drive I'd go for a MOSFET myself.  They are resistance
devices.  You might be able to drive them from the I/O pin.  If you use a
logic level FET and drive them at 5V you certainly will be able to.
First I'd check what the drive for that solenoid is supposed to be though,
that's an awfully low resistance.  I rather suspect it's shorted.  Have you
got a part number/data sheet link?
Hmm, there is another possibility.  I've run into this in the past on some
contactors that have four quick connect tabs on the coils.  The first
instinct is to connect across the two quick connects on the top or bottom
of the device.  Unfortunately those are connected to the same side of the
coil and you can end up trying to drive a lot of current to no effect.  Any
possibility you are not actually measuring across the coil but rather
somewhere else?
Robert
" 'Freedom' has no meaning of itself.  There are always restrictions,   be
they legal, genetic, or physical.  If you don't believe me, try to chew a
radio signal. "  -- Kelvin Throop, III
2005-11-02 by Rob Jansen
And do not forget to add a diode accross the FET, some MOSFETs have a
diode built in but it may be too small, depending on your load.
Solenoids and things like motors have huge coils - keep this in mind
when designing.
Check your mosfet of choice for Rds and Vgs. Rds is the resistance of
the FET when fully open (saturated) under specific conditions.
Vgs is the voltage you need to open the channel (this is a bit simple
but will do to get an idea).
So a MOSFET with Vgs = 20V will not do for a 3.3V lpc21xx controller,
you may want to go for a different part.
Nice parts are the IRF540
(http://www.irf.com/product-info/datasheets/data/irf540.pdf), Vgs =
2-4V, Rds = 0.077 ohm.
Id (continuous drain current) is 28 Amps (at Vgs = 10V, so it will be
less when driven by the lpc21xx directly).
For smaller currents check out the IRF7403 (it's an SMD package ...) Vgs
= 1V, Rds = 0.022 ohm, Id = 8.5A.
It's big enough for most of my applications and I tend to use this one
instead of a standard NPN transistor when driving small loads (up to a 2
amps).
I get these part from http://www.reichelt.de (German ...) and the 540
costs 0.52, in SMD version 0.70 and the 7403 is 0.42 - all prices in Euro.
I prefer the SMD parts. Since I design, etch and drill my own PCBs for
home projects I prefer SMD.
Creating SMD layouts and transfering this to photo sensitive PCB
material is easy to do (I use HPs overhead film).
Drilling holes is not only time consuming but I also tend to break the
(fairly expensive) drills from time to time ...
    Rob
except from the nice smoke effects that is :-)
2005-11-02 by Tom Walsh
>when designing.
I generally use a 2N7000 or 2N7002 FET for driving relays.  They can
sink up to 100ma easily and have an internal clamping diode to protect
the gate when the coil (de)energizes.
TomW
>amps).
>Regards,
>    Rob
>Yahoo! Groups Links
>when designing.
Good thing to check although I've not seen a power FET whose integral body
diode wasn't rated for a much current as the FET itself.  More important
make sure the coil is properly suppressed either with a diode or some other
circuit.
Have you ever seen a MOSFET rated for a threshold that high?  If you are
taking about logic level FETs I have seen VGS max of +/- 20V fairly
commonly on logic level FETs.  I think the highest threshold I've seen for
VGS was about 5V.
Well maybe, That 4V is the maximum for the threshold voltage so to
guarantee turn on you need to drive above that voltage. preferably at 10V
or more.  It will work at 5V although with higher RDS.  It might work at 3V
but you'd be right at the turn-on knee so you would be taking a chance.
>amps).
Now that's a logic level FET.
That's what over-current circuits are for :)  You can't expect the end
users not to make an occasional mistake hooking up a coil and of course
they do short from time to time.  Now if they hook up the power leads to
the motor controller backwards that's another story entirely ;)
Robert
> >when designing.
Well the original post did say they had a 2 Ohm coil.  That in turn would
suggest a multiamp drive was needed.  That diode in the 2n7000 won't
protect against inductive spikes though, it's in the wrong part of the
circuit.  You are probably getting avalanche breakdown and I don't think
I've seen a data sheet for either of these parts with an avalanche rating.
Robert
2005-11-03 by Tom Walsh
>>>when designing.
OW, missed that one!  Well, bigger FET and larger diode(s) then...
Perhaps an IRF530, lots of power in that, somewhere around 6 AMPs,
IIRC.  It could also be switched from 5volt logic.
Trouble with transistors is that they are current devices, they magnify
current based on the beta (gain) of the device.  You don't suffer that
problem with an FET as it controls current with a voltage on the GATE
(low current draw on the control voltage).  Definately would go with a
MOSFET or BI-FET.
TomW
2005-11-03 by Peter Jakacki
Solenoids require a lot of current to "pull-in" the plunger. After the
plunger has been pulled-in a smaller amount of current is all that is
required to hold it. Some solenoids may have two windings, the primary
high-current pull-in winding, and the secondary low-current hold
winding. These windings may be switched over internally by the plunger
action. If your solenoid has only a single winding you will find that
the large amount of current flowing will produce heating effects. It is
usually advisable for this reason, and also for reduced current
consumption that the winding be switched to a lower current either by
means of reduced voltage or by the PWM method. The PWM could be
implemented in sw as it only needs to be a low frequency.
If a bipolar transistor is used to drive the solenoid then it will
usually require a significant amount of base drive current to achieve
saturation, much more than a logic pin can usually provide. The device
of choice for driving solenoids has to be the MOSFET due to the fact
that it requires practically no current to drive, it features an
integrated clamp diode, and they are available in special configurations
such as autoprotected.
Although it is true that you don't need a resistor in the gate drive
circuit it is good practice to include one in the event of a MOSFET
failure for whatever reason and there is a breakdown from drain to gate
(yep!). In which event the unprotected logic device will release it's
magic smoke and forever cease to function.
2N7000s are unsuitable for anything but small signal or very low-current
(IMO, don't use them). The IRF7403 that was mentioned is a good
candidate for medium power drive. Personally, if I have room I allow for
standard TO-220 through-hole parts. My favorite is the IRF3205, they are
cheap and being rated at 110A are hard to destroy, the pcb tracks
vaporise first.
I find that due to the excellent clamp action of the integrated diode
that an external coil diode is not (never) required. Also, but not very
importantly, the breakdown voltage of the integrated diode allows the
magnetic field to collapse faster increasing the response time of the
solenoid release. If for instance you were driving a relay and needed
faster release, you would not use a normal diode across the coil. You
could either feed the power via a series fast-zener (etc) or depend upon
the integrated diode. Which by the way means that the coil needs to dump
it's current in reverse through the power supply so it is advisable to
have a diode (preferably a transzorb) device across the supply rails or
you could find those voltage spikes appearing at rather sensitive places.
Summary: use low RDSon low Vgs mosget with series resistor (10K-100K),
along with a clamp diode across the supply.
*Peter*
Re: Solenoid Control.
2005-11-03 by charlesgrenz
Hi Tom,
  We use a IRFD110 (Hex Dip MOSFET) with a 1N4001 diode to control 0.5
amps in a very small package. They are also logic compatiable.
regards,
Charles
resistance
you use a
> >>>when designing.
would
think
rating.
> MOSFET or BI-FET.
> TomW
