MOTM
peak and trough - is it cool?
2001-02-09 by mate_stubb@yahoo.com
Has anyone ever played with either a Serge or Modcan Peak and Trough
module? What kinds of cool stuff can you do with it?
I've been thinking I might build one up. Seems to me all you need are
some analog gates and comparators to control them.
Moe
RE: [motm] peak and trough - is it cool?
2001-02-09 by Brousseau, Paul E (Paul)
What is it supposed to do on a basic level, exactly?
--PBr
Sent: Friday, February 09, 2001 1:33 PM
To: motm@yahoogroups.com
Subject: [motm] peak and trough - is it cool?
Re: peak and trough - is it cool?
2001-02-10 by mate_stubb@yahoo.com
You have multiple inputs, say 4. You have a PEAK output and a TROUGH
output. The PEAK output always has the instantaneous highest voltage
from any input, and the TROUGH output always has the instantaneous
lowest voltage from any input.
You are supposed to be able to generate weird control voltages with
it, I'm just wondering if it's a valuable thing to do.
Moe
Re: [motm] peak and trough - is it cool?
2001-02-10 by davevosh@aol.com
In a message dated 01-02-09 16:35:20 EST, you write:
send me your address and i can send you a schematic. it is quite a simple
module to build and would be worth checking out. serge sent me a copy years
ago after he stopped making them.
best,
dave
Re: [motm] Re: peak and trough - is it cool?
In a message dated 01-02-09 21:20:04 EST, you write:
i found it to be useful back when i had a serge. its easy diy level makes it
a good add-on for those who like to build.
best,
dave v.
2001-02-10 by Tentochi
Dave--
Would you mind sending it to the whole list?  I am sure it would be greatly
appreciated by many of us.
--Shemp
> copy years
> best,
> dave
2001-02-10 by norman fay
In message <961nmu+ndve@...>, mate_stubb@... writes
>Moe
I have the modcan morph wave/peak&trough module (morph wave is like 2/3
of the serge triple waveshaper module, 'though modcan adds an invertable
CV pot to each waveshaper, which is very useful.)  You can plug any
amount of inputs from 1 to four into it, and the two outputs give you
the highest voltage and the lowest at any point in time.   I must
confess that my explorations with this function have been a bit limited,
and the effect is quite hard to describe as well.  Feeding it with just
two VCOs, the effect is similar to a ring modulator in that it
accentuates the beating effect when they are close-tuned, and becomes
quite dissonant when they are tuned to inharmonic intervals.  Using more
than two VCOs - well, you'd better then run it through a low pass
filter, is all I'll say...!
I think I'd describe it as a "lets try it and see what happens" type of
module - not one of the essentials, but kind of unpredictable, fun &
interesting.  So it *is* cool...looking at the PCB of the modcan module,
the circuit looks REALLY simple as well.
Hey! As I write, I've just finished cutting a flat-pack pine bookshelf
to size on the work sawbench, thus turning it into a 3-row x 7-column
motm rack (gulp - I've got a *lot* of spaces to fill now!)
I got my 4 modcan modules last week, BTW - ladder filter,
phaser/waveshaper, dual LFO and wavetable.  I'll report on MOTM
compatibility after this weekend
best etc.
norman fay
2001-02-11 by davevosh@aol.com
In a message dated 01-02-10 08:01:54 EST, you write:
sadly, i have no way to scan it or get it on line.
the offer is open to anyone, though..... send me your snail mail address and
i`ll send one off to you.
best,
dave v.
2001-02-11 by J. Larry Hendry
Send it to me.  I'll scan it and put it on line if you like.
Larry H
To: <motm@yahoogroups.com>
Sent: Saturday, February 10, 2001 7:10 PM
Subject: Re: [motm] peak and trough - is it cool?
best,
dave v.
2001-02-11 by jhaible@t-online.de
and
If the goal is to get a precise minimum and maximun of several input CVs,
I have something like than in my polymodular interface to derive the highest
and lowest note from a number of polyphonic keyboard CVs.
(see my homepage -> Schematics -> Polymodular for details)
If precision is not needed, just build an "OR" and and "AND" function
from N diodes and one resistor, buffer it with an opamp, and includ another
diode in the feedback of the opamp to get a crude compensation for the
diode drop of the input network.
JH.
In a message dated 01-02-10 20:16:59 EST, you write:
<< Send it to me.  I'll scan it and put it on line if you like. >>
larry,
one will go out to you monday. feel free to scan and put in the motm files /
archive section.
best,
dave v.
In a message dated 01-02-11 04:11:09 EST, you write:
 J >>
jurgen,
and this is the approach used here......
best,
dave v.
> jurgen,
> best,
> dave v.
Ahh, I see. Beauty lies in the simple things.
The "crude" diode approach has the advantage of being faster, of course.
(My opamp circuit is precise, but not intended for processing highest
audio frequencies.)
JH.
2001-02-11 by sikorsky
and
i'd love to see a copy - and i hereby offer to forward it to any of the UK
chaps on the list
cheers
Paul R Bower
Axis Studios
3 Brown Street
Sheffield
S1 2BS
United Kingdom
In a message dated 01-02-11 09:59:12 EST, you write:
 audio frequencies.)
jurgen,
it is an extremely simple design !  it trades off precision for basic
functionality and uniqueness. it is worth adding to a modular on this basis
alone plus, for me, being interested in algorithmic type sound structures, it
helps create the ability to do logic desicions in conjunction with electronic
switches and assorted sources of c.v. or gate/trigger/timing functions.
best,
dave v.
In a message dated 01-02-11 11:29:23 EST, you write:
 chaps on the list
 cheers
 Paul R Bower
 Axis Studios
 3 Brown Street
 Sheffield
 S1 2BS
 United Kingdom
paul,
i`ll send you a copy monday. feel free to do whatever.
best,
dave v.
