Fw: mixer demo
2001-06-14 by Paul Schreiber
Hey Paul - Here's a short demo of 3 different voices mixed together on the 830. Each voice was mangled separately then brought together in the mixer and fed through the VA to the 410 to the recorder. Voice one uses a 300 with TRI, SAW, and PULSE voice outs into IN 1 through 3 of the 420. Each input knob is at max, so I get distortion from the 420. The OUT of the 420 goes to IN 1 of the mixer. The second voice has the 300's SIN feeding the A IN of the 120. The B IN is fed by the PULSE out of the 320 LFO (which also syncs the 101). The 120 is in CROSS mode with only SUB 1 & 2 turned up. The out goes to the 440 whose EG is controlled by the same EG as the 420. The OUT goes to IN 2 of the 830 mixer. Finally, the SAW out of a second 300 feeds X IN of the 110, while the TRI out of the LFO feeds Y IN. The OUT of the Ring Modulator then goes to IN 3 of the mixer. Amazing. Mike
