MOTM
[motm] Flute & Recorder MP3's with BC3
2001-08-19 by elhardt@aol.com
Finally refined my MOTM flute patch and it now uses Breath Control for
expression, loudness, brightness, tremelo, flutter tongue (a little messy but
it's something).  Part of the flute patch also does a nice Renaissance
recorder.  Two knobs control how much recorder gets mixed with the flute.
Following are some short snippets, about 400K and 1300K respectively.  MOTM
one right hand of split keyboard, Rompler on left hand.
http://members.aol.com/elhardt2/motm_recorder.mp3
(Mannheim Steamroller / Gentle Giant)
http://members.aol.com/elhardt2/motm_flute.mp3
(Debussy / Improvised / Bach)
-Elhardt
Re: Flute & Recorder MP3's with BC3
2001-08-20 by Mike Marsh
you've stunned the entire list into respectful silence...
for
messy but
Renaissance
flute.
respectively.  MOTM
> -Elhardt
Re: [motm] Flute & Recorder MP3's with BC3
2001-08-20 by George Kisslak
Uhh............
WOW.
maybe some Jethro Tull next?
George
To: <motm@yahoogroups.com>
Sent: Saturday, August 18, 2001 11:04 PM
Subject: [motm] Flute & Recorder MP3's with BC3
but
MOTM
> -Elhardt
2001-08-20 by elhardt@aol.com
Mike Marsh writes:
>>you've stunned the entire list into respectful silence...<<
The weekends are always really slow message posting days.
George Kisslak writes:
>>WOW.  maybe some Jethro Tull next?<<
First I need to synthesize Oboe, Bassoon, Bass/Tenor Recorders and start
multitracking all these sounds to see how a whole group of them playing at
once sounds.
-Elhardt
2001-08-20 by robs7@aol.com
don't know if everyone was out enjoying their weekends, emailing eldhart
directly, reading/posting "MOTM vs Doepfer", or what, but since it seems like
eldhart got such a quiet list response...
The flute/recorder patches sound great. Excellant synthesis. Really really
impressive. The same goes for the brass patches Paul put on the site.
Im stuck using a ROMpler often for flute sounds live and in recording.
Getting a good flute sound is a priority for me from my MOTM (its the only
imitative sound I "need,' however I need it to be less European classical
music and more Cuban) and your patches are inspiring. Dont have a 410 yet--Im
trying to solve immediate casing needs first--but your patches almost make me
order one right away so I can try to copy some of what you did. (patience is
winning this time, but for how long can I hold out?????)
The patch sheets are a great idea as well.
Thanks for sharing your sounds and ideas!
Rob
2001-08-21 by elhardt@aol.com
robs7@... writes:
>>The flute/recorder patches sound great.  Im stuck using a ROMpler often for
flute sounds live and in recording. Getting a good flute sound is a priority
for me from my MOTM (its the only imitative sound I "need,' however I need it
to be less European classical music and more Cuban) and your patches are
inspiring.<<
Thanks for the compliments.  I noticed when patching up the flute patch that
if I cranked up the oscillator FM knob that causes more breath from the BC3
to change the pitch, that I started to get a more primitive flute sound,
possibly more along the lines of some South American Andean type instrument.
And I'm sure there are probably a bunch of other things that could be
modified.
>>I am quite simply beaten with amazement.  I had no idea this was possible.
What's next, anybody got a good accordian patch HA! Seriously though it would
be great to hear some guitar and drums samples too. I am working on drums but
I would love to hear everybodies impressions and versions of MOTM
percussion.<<
Again thanks for the comments.  Guitars are probably better done on a
polyphonic and I'm going to be doing more of that on the Nord Modular.  If
played through a distortion unit, the polyphonic notes affect the sound in a
way that doesn't happen when just playing one note at a time.  And percussion
was also something I was considering doing on the Nord Mod but might do some
on the MOTM.  But I will probably stick to the cymbals I did on my JP-8080
because they require the full resources of a polyphonic synth.  Link below
for sound snippet which shows a milder cymbal strike patch (kind of like ride
cymbal) followed at the end by a huge cymbal crash patch.
http://members.aol.com/elhardt/images/cymbals.mp3
mate_stubb@... writes:
>>Ken, does the Yammy BC allow enough control to do brass tongueing
techniques, reed bites, etc?<<
All it does is sense breath pressure.  Although if you also make a vocal
sound with your throat it sounds different for some reason.  If you want to
get more elaborate then that, then you will probably want to hook up foot
pedals or something else to further control and alter the sound.  I wish the
BC3 could sense reverse breath so if you sucked in you could use that to do
something different or output negative values.
-Elhardt
