MOTM
[motm] Flute/Recorder Patchsheet Up
2001-08-23 by elhardt@aol.com
You asked for it so here it is:
http://members.aol.com/isobarb8/fluterec.jpg
Note: Sometimes it's easier to use a second duplicate module then run a
single module through a multiple.  As a result it might be possible to use
just 1 pink noise source and one LFO.  Also left over in some experimenting
is an ADSR controlling a second VCA.  It's possible both those could come out
also with no adverse affect.  But I'm just putting down exactly what I have
so as not to mess anything up.  Also as I mentioned earlier, the settings on
the 410 triple filter are touchy and will vary between systems, so the best I
can say is set up as I have then go by ear from that point on.
-Elhardt
