MOTM
Re: [motm] actually, 420 mod? (phasers)
2001-08-25 by elhardt@aol.com
>and another part of my reluctance to purchase a 420 is that I've not found
notch filters all that useful)<
>>Two filters in series in *Notch* mode emulate a 4-stage phaser. With a
single filter (one notch) the effect is too weak for being recognized as
phaser<<
And to add to this thread, since I bought an oscilloscope several months ago
I was able to hook up two probes to the MOTM.  One before a filter and one
after, which allows you to easily see the phase shifted output of the filter
as you sweep the cutoff frequency around.  So when you mix the sound before
the filter with the filtered sound and sweep the cutoff you get a phaser
sound.  Now hook up a bunch of filters and create the ultimate custom
phaseshifter.
-Elhardt
2001-08-25 by Paul Schreiber
And if the scope is X-Y, hook original into X and output into Y. Then, sweep
at about 100Hz with a triangle :)
Watch the pretty pictures :)
Paul S.
To: <motm@yahoogroups.com>
Sent: Friday, August 24, 2001 10:46 PM
Subject: Re: [motm] actually, 420 mod? (phasers)
found
> phaser<<
ago
filter
before
> phaseshifter.
> -Elhardt
