MOTM
VC res on a '420
VC res on a '420
2001-08-27 by Paul Schreiber
Try this:
a) set RES to 0 on the panel
b) plug out into mult
c) plug 1 mult out into '110 X IN
d) set X on AC, Y on DC
e) use ADSR OUT + into Y IN
f) output of RM into one of the AUDIO INs of the '420
so, we are applying the filter output back into it's input, trrough a 'VCA'.
This is essentially how all
VC Q is done.
Paul S.
Re: VC res on a '420
2001-08-27 by George Kisslak
on Monday, August 27, 2001 3:05 PM Paul Schreiber <synth1@...>
wrote:
> Try this:
'VCA'.
> VC Q is done.
> Paul S.
This makes sense - thanks Paul.  In the earlygoing, I had tried simple
feedback loops with each of the filters (as well as other modules) to help
me learn about their sonic characteristics.  I had noticed that this
feedback was very similar to the res control.  (Believe me, I'm still
learning!)  I've also experimented with chaining a 420 to a 440 and feeding
back the 440 output to a 420 input - different and cool.
I haven't tried it yet, but I bet applying the technique you've described
above with a 410 would produce *interesting* results.
So, I'm thinking a "filter companion module" to add this VC res
functionality (and maybe provide access to the resonance loop) would be
useful, eh?  Or maybe a daughter board to hold the VCA and add a jack for
res-in (and possibly res-out).
George
2001-08-27 by Mike Marsh
OK Mr. Smarty-Pants, so if I want access to the feedback path for
resonance, this is how I would do it.  Correct?
Mike
--- In motm@y..., "Paul Schreiber" <synth1@a...> wrote:
> Try this:
trrough a 'VCA'.
> VC Q is done.
> Paul S.
Re: [motm] VC res on a '420
2001-08-28 by elhardt@aol.com
synth1@... writes:
In the past the only way I was able to get decent sounding filter resonance
by feeding the output back into the input was to invert the signal.  I used
the MOTM mixer for that.  Unless the RM inverts the signal it probably won't
work properly.
-Elhardt
