MOTM-850 Pedal mockup
2001-08-25 by Paul Schreiber
Go to www.synthtech.com/pix you will see it there (with other random stuff). Thanks to Moe for the pix and Stooge Larry for the testing (cough cough). Paul S.
2001-08-25 by Eric Frampton
Paul Saith: > you will see it there (with other random stuff). Does the Mix control change the amount of Mix In CV summed with the internal CV, or does it mix -between- the two? I.e., would it be possible to create a CV out of 30% 850, 70% Mix In? If not, could it, or should it (and thus make the scale of that knob not 0-10, but 0-100%)? Also, and pardon my complete ignorance here, is this module's job to basically take a non-powered CV pedal and power it up? Would simply plugging in an old Moog 1130 CV pedal, which outputs 0 to 5v, accomplish much of the same result (obviously without the scaling or Triggering options)? And, when Paul (or Larry, I forget which) mentioned Yamaha-style pedal, do you mean the optical ones (like what came with my old DX7), or is there another one? Just as long as you can hook those generic everybody-rebadges-them-but-they're-just-cheap-Fatar CV pedals up to it... Thanks, Eric ----- Eric Frampton, keyboards Atlanta, Georgia, USA web: http://www.ericframpton.com/ email: eric@...
2001-08-25 by elhardt@aol.com
eframp@... writes: >>Also, and pardon my complete ignorance here, is this module's job to basically take a non-powered CV pedal and power it up? Would simply plugging in an old Moog 1130 CV pedal, which outputs 0 to 5v, accomplish much of the same result (obviously without the scaling or Triggering options)?<< When a couple of other people seemed disappointed that the 850 would only handle one pedal I was going to mention that they can use as many powered pedals as they want, but I didn't want Paul thinking I was trying to talk people out of buying the 850. I have one of those old Moog pedals I was just about to plug in myself. However that pedal doesn't operate as nicely as the Roland and probably Yamaha pedals. In the past I always seemed to have problems getting it to control a parameter and match up with the pedal position the way I wanted it too. That's probably because of its lack of scaling and offset controls. Although most MOTM modules have an input level pot. -Elhardt
2001-08-25 by J. Larry Hendry
One feature perhaps not mentioned is that the 850 will also accept this type of CV pedal in the pedal input. So, you can still use that pedal and get the added features of offset and range. For all you guys that think the Roland EV pedal is nice, you must not have tried the Yamaha FC-7. The Yamaha is far superior to the Roalnd pedal in every way. Buy yourself one and you will never go back. I have 3 FC-7s. Two have 12 years of gigging on them. The third is my spare, which I have never needed. Larry Hendry
----- Original Message ----- From: <elhardt@...> I have one of those old Moog pedals I was just about to plug in myself. However that pedal doesn't operate as nicely as the Roland and probably Yamaha pedals. In the past I always seemed to have problems getting it to control a parameter and match up with the pedal position the way I wanted it too. That's probably because of its lack of scaling and offset controls. -Elhardt
2001-08-26 by The Old Crow
One tiny suggestion: put a 3.5mm jack near the left edge so I can plug in a BC-1. If a stereo 1/4" to 3.5mm will suffice, never mind. :) Crow /**/
On Sun, 26 Aug 2001 mate_stubb@... wrote: > Crow: what exactly does a BC-1 or BC-3 output? Direct CVs? It is just a strain-gauge pot: tip is "wiper", ring is +5V, shield ring is common. +5V is supplied to the BC-1 from, say, a DX7 BC jack. I've never used a BC-3, but I would think it to be similar. Crow /**/
2001-08-26 by Paul Schreiber
> > Does the Mix control change the amount of Mix In CV summed with the internal > CV, or does it mix -between- the two? I.e., would it be possible to create a > CV out of 30% 850, 70% Mix In? If not, could it, or should it (and thus make > the scale of that knob not 0-10, but 0-100%)? It adds whatever you plug into it with the Pedal CV. The Pedal CV is at 100%. The Mix pot in an input attenuator. So, MIX IN could be from a keyboard and then Pedal adds swooping (foot-powered ribbon controller :) ) > > Also, and pardon my complete ignorance here, is this module's job to > basically take a non-powered CV pedal and power it up? Would simply plugging > in an old Moog 1130 CV pedal, which outputs 0 to 5v, accomplish much of the > same result (obviously without the scaling or Triggering options)? Old Moog pedals aren't exactly commonplace (although I have one). You can plug in a CV into Pedal IN due to Stooge Larry's clever input scheme. > > And, when Paul (or Larry, I forget which) mentioned Yamaha-style pedal, do > you mean the optical ones (like what came with my old DX7), or is there > another one? The interface is tested with Roland EV-5 and Yamaha FC-5 and FC-7 pedals. Any 'resistive' pedal will work. There is a jumper to select the resistance of the pedal pot (10K, 50K or 100K). Paul S.
2001-08-26 by mate_stubb@yahoo.com
>>>> One tiny suggestion: put a 3.5mm jack near the left edge so I can plug in a BC-1. If a stereo 1/4" to 3.5mm will suffice, never mind. :) Crow <<<< Crow: what exactly does a BC-1 or BC-3 output? Direct CVs? Moe
2001-08-27 by mark@indole.net
>The interface is tested with Roland EV-5 and Yamaha FC-5 and FC-7 pedals. >Any 'resistive' pedal will work. There is a jumper to select the >resistance of the pedal pot (10K, 50K or 100K). I'm confused here, but isn't a resistive pedal simply a pot set up as a voltage divider?? If so, why would the value of the pot matter??
2001-08-27 by Paul Schreiber
Because clever Stooge input, that senses Yamaha or Roland (wired differently, just to be a pain in the ass) uses a *current*. Paul S. ----- Original Message -----
From: <mark@...> To: <motm@yahoogroups.com> Sent: Monday, August 27, 2001 1:51 PM Subject: Re: [motm] Re: MOTM-850 Pedal mockup > > >The interface is tested with Roland EV-5 and Yamaha FC-5 and FC-7 pedals. > >Any 'resistive' pedal will work. There is a jumper to select the > >resistance of the pedal pot (10K, 50K or 100K). > > I'm confused here, but isn't a resistive pedal simply a pot set up as a > voltage divider?? If so, why would the value of the pot matter?? > > > > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > >
